21st Feb 2017, 11:46 am | #1 |
Dynatron SRX 20 Speakers
I'm repairing a Dynatron SRX 20. I've managed to track down and install a CA3094A op amp and now got the thing working, however one of the bass speakers has come off centre and I will need to find a replacement. I'm measuring about 12 ohms D.C resistance. It measures 8 by 5". Does anyone know where I could get a replacement from? Has anyone got anything suitable lying around? Many thanks, Tim. |
21st Feb 2017, 12:03 pm | #2 |
Re: Dynatron SRX 20 Speakers
I might have one - could you post a pic so I can check?
Roger
'....don't go mistaking Paradise for that home across the road!' (Bob Dylan) |
21st Feb 2017, 2:20 pm | #3 |
Hello Roger,
Thanks for the reply, please see photo. Thanks again, Tim. |
21st Feb 2017, 2:39 pm | #4 |
These were originally Goodmans units and as you can see have a treated cone. There will be lots of 8" x 5" @ 3 ohms around I'm sure, but the 12 ohms impedance are not such an easy find. The right sized Car Audio speaker will only 4 ohm.
Edward. |
21st Feb 2017, 2:59 pm | #5 |
Hello Tim - I have a couple of spare 8 X 5s - one is a Fane, the other doesn't admit to being made by anyone but it works and looks OK - you are welcome to either. Just spotted you are in Bristol - whereabouts?
Cheers Roger
21st Feb 2017, 3:07 pm | #6 |
You'll need to check the impedance of those speakers, Roger, and the 'OP' needs to re-check the impedance of the one he's got to make sure he's got it right.
21st Feb 2017, 3:28 pm | #7 |
The Fane speaker is likely to be 3 ohms and the other, which lookes like a Grundig, is likely to be 5 ohms.
Edward. |
21st Feb 2017, 5:04 pm | #8 |
So I should! They both measure just under 7 ohms. I can spare a pair of either if that helps.
21st Feb 2017, 5:16 pm | #9 |
Hi guys,
thanks for replying. I'm measuring 14 ohms on both my AVO and dmm so I guess I'm a bit stuck! Thanks all the same Roger. Thanks again guys, Tim. |
21st Feb 2017, 5:34 pm | #10 |
I thought so! Yours is a 15 ohm and Rogers are 8 ohm.
Why don't you have a go at fixing yours and keep things original? Many forum members have fixed off centre speakers and if you have a look, there's quite a bit of information on doing it in past threads. Mounting the speaker upside down in the cabinet can sometimes make it 'sag' the other way and cure the problem - I did this with a speaker in an old tape recorder the other day! |
21st Feb 2017, 6:19 pm | #11 |
Has the cone rear suspension become unstuck? It's uncomon for this sort of small speaker to go out-of-centre without some sort of damage.
21st Feb 2017, 6:57 pm | #12 |
Hi guys,
Thanks for all your help. It's funny but I have repaired a lot of speakers lately. I've replaced foam surrounds and repaired cone rear suspension. I didn't realise you could recentre a cone. The rear suspension in this case is fine but I have never seen a speaker come this far off centre and turning it upside down won't fix something this far gone. The cone is badly rubbing so much so that the cone gets stuck. I would be up for giving this a go. Anyone got any advice? |
21st Feb 2017, 7:01 pm | #13 |
These are downward firing Bass/Midrange only units, mounted undeneath the Radiogram with seperate mid range/tweeters to each side. A replacement bass/mid range unit will need to have a good cone excursion to match the original sound of the Dynatron.
Edward. |
21st Feb 2017, 10:57 pm | #14 |
Use a scalpel to remove the central dust cover from the cone, then you can use shims of, say, card to centre the voicecoil. It's unclear what's moved here though - it looks like a glued magnet, which wouldn't move without falling off altogether. Has the cone got damp, perhaps? It looks in good nick.
Otherwise, there might be something in the airgap, metal filings for instance. |
22nd Feb 2017, 10:08 pm | #15 |
Hi guys,
I cut off the dust cover today and had a look but couldn't really see the cone rubbing. I'm quite confused as the speaker seems to be freer to move now that I've been manually compressing the cone. I don't really get what's going on but I'm going to put the speaker back in tomorrow and see how it is now. It's not getting stuck like it was. I'll report back tomorrow. |
23rd Feb 2017, 12:14 am | #16 |
If it does face down, perhaps something was lodged in it and has now cleared unnoticed?
