19th Feb 2017, 5:33 am | #1 |
Decca Decola amplifier restoration
Split from this thread: https://www.vintage-radio.net/forum/...d.php?t=133868
Starting to restore the Decola PSU and amplifier. Strange at it seems,with exception of two 600 Ohms 3w resistors,all the rest of the resistors are or precise or in the 10% of mesurment.All the litycs are out as also the coupling PIOs. As i don't have the schems of it,(and it would be very welcome if any of you have),i'm having some trouble in identifying what's seems to be 6 tinny ceramic caps of 4pf,that i would like for you, if know what it is,try to help me identify them. Please check the pics Thanks Last edited by AC/HL; 19th Feb 2017 at 2:21 pm. Reason: Thread split |
19th Feb 2017, 3:41 pm | #2 |
Re: Decca Decola amplifier restoration
The 4pF capacitors are for neutralisation
They reduce the effective input capacitance of the Triodes.( from around 90pF to 4pF) The closest modern equivalent would be 3.9pF Cheers Mike T
Invisible airwaves crackle with life or at least they used to Mike T BVWS member. www.cossor.co.uk Last edited by Cobaltblue; 19th Feb 2017 at 3:46 pm. |
19th Feb 2017, 7:19 pm | #3 |
Hi Mike,
Thanks! And what voltage should I get? |
19th Feb 2017, 7:38 pm | #4 |
During warming up these capacitors could be subjected to full HT for a short period so I go for 500V parts which I think is what the originals are.
Cheers Mike T
19th Feb 2017, 7:49 pm | #5 |
Mike,Thank you so much!
20th Feb 2017, 3:26 am | #6 |
Mike,
Perhaps you can help me on this! there are two strange resitors they have more strips colors then usual,they are in both PX25 output plates before output trasformer primary,it reads 45ohms but colors are:magenta,yelow,black,yelow,silver please check the pics.Where can i find the electronic diagram? Cheers |
20th Feb 2017, 6:07 am | #7 |
Hi Carlos, the ceramic caps probably do not need changing as they seldom go leaky. They could also have a neg temperature coefficient to reduce tuning drift. Paper caps, certainly replace them.
Ed |
20th Feb 2017, 6:50 am | #8 |
Hi Carlos
The circuit can be obtained here: http://www.service-data.com/product....05/1623/a11205 If they are in the Anode of the PX25's then they are 47 Ohms Ed at least one of the Capacitors has physically failed please see the pictures in post #1, they are in the power amp not the RF stages Cheers Mike T
20th Feb 2017, 9:10 am | #9 |
Mike Once again THANK YOU!!!
20th Feb 2017, 9:16 am | #10 | |
Unfortunately those caps have to be replaced as soon as you touch them they tend to loose there contact wires, i have attached a pic of it... |
20th Feb 2017, 2:54 pm | #11 |
Mine were the same and I replaced them all. They are used to reduce the miller effect by 'cancelling out' the grid/anode capacitance using the opposing valve in each pair. It's a true differential design all the way from the pickup matching transformer. Might be interesting to see if they really make a difference to the HF response. There is no overall -ve feedback so the design is reliant on the valve performance.
28th Feb 2017, 2:04 am | #12 |
For thouse who never had the opportunity of seeing a Decca Decola insides...
28th Feb 2017, 2:07 am | #13 |
a few more...
1st Mar 2017, 1:29 pm | #14 | |
This system included some interesting monochromatic resistors in 20% (no tolerance marking) types like 2.2k (all red) and 33k (all orange). Other possibilities exist but would have been non standard values like 110R, 440k etc.
2nd Mar 2017, 3:13 am | #15 | |
13th Mar 2017, 4:55 pm | #16 |
Hi there,
After everything desmonted,re-glued,wood compensated etc,I'm stucked with a gear that holds the cover from flick back. It must be easy to desmont but I just can't see how...any tip about to do it would be super! Much easier to polish it with separated parts... |
