22nd Jan 2017, 11:39 pm | #1 |
Schwabe retro strip light capacitor help
Hi all.
Been asked to look at a German made Schwabe portable strip light that had been knocked over and now does not work. On opening to investigate found a 0.01uf capacitor with some brown powdering on one end and on the chassis it was touching (looked like it had spilled out from the cap). I did test the cap on a cheap cap tester set to 10nf and it was flickering between 14 and 17nf so not sure if it is ok. I typed the number (60.0711.013) on the cap into the internet and it came up with only one result, a forum in German which was of little help finding replacements. The cap is 0.01uf 250v condensing cap I believe and I would like to know what I could replace it with? Will any non electrolytic cap do? The transformer type power unit does hum slightly when turned on. Cheers. Gaz. Last edited by tracypaper; 22nd Jan 2017 at 11:44 pm. Reason: added extra info |
23rd Jan 2017, 6:51 am | #2 |
Re: Schwabe retro strip light capacitor help
As far as I can see its just a 10nF 250VAC X rated capacitor.
see this link https://electrosome.com/x-and-y-rated-capacitors/ Cheers Mike T
23rd Jan 2017, 10:07 am | #3 |
A capacitor that small is most unlikely to be anything directly related to correct operation of a fluorescent lamp and the light should work without it, if all else is in order.
The small capacitor is probably for radio interference suppression and it would therefore be good practice to replace it before regular use of the light, but no need for testing or locating other faults. |
23rd Jan 2017, 11:10 am | #4 |
Daft question, but have you tried another tube? The knock may have rendered one or both heating filaments open circuit. Cheers, Pete.
24th Jan 2017, 1:23 am | #5 |
The tube I am using is supposed to be a new one, but I will get some more to try just in case.
Where can I get an X rated cap from? Cheers. Gaz. |
24th Jan 2017, 11:53 am | #6 |
Hi Gaz, I have one you can have, if it will fit. Please remind me of your address by Pmail and I will get it sent.
John. |
25th Jan 2017, 1:13 am | #7 |
Cheers.
PM sent. |
28th Jan 2017, 8:58 am | #8 |
Before getting a new tube you should test the heating filaments at each end of the tube for continuity, should be in the low ohms range.
Lee |
1st Feb 2017, 7:27 pm | #9 |
Any chance we could get some more details on the light and possibly a photo of the ballast?
If it's an SRS setup there will be a cap in there which is critical to starting, though what value I don't know off the top of my head. If it's a conventional switch-start setup (dead giveaway is that there should be a separate starter), the cap should be none-critical, and there's not a huge amount to go wrong. Dead starter, wiring fault, dead lamp or faulty ballast. You should be able to check for continuity with a meter, no need for any live measurements. If it uses an electronic ballast things are a bit more complex as they are basically small switch mode power supplies and there's more to go wrong. |
4th Feb 2017, 1:38 pm | #10 |
Hi
It is an SRS set up as Zelandeth suggests (no seperate starter). I have replaced the Ballast thing and all work now. Thanks for the advice everone. Gaz. |
