Old 21st Dec 2016, 9:58 pm   #1
skodajag
Default Control knob lettering
I need to re finish the front panel of a post war HMV set and am looking for a source of replacement control knob lettering (bass, treble, gram etc). The original is small stick on gold lettering about 4mm high. I'm ideally looking for someone who will supply the complete words in stick on form rather than just the letters - getting the latter evenly spaced and level would be tedious. Any suggestions? Thanks, Jonathan.
Keep Calm and Carry On Restoring
skodajag is offline
Old 22nd Dec 2016, 8:03 am   #2
dseymo1
Default Re: Control knob lettering
Try a signwriter.
These days, they work mainly with computer-controlled vinyl cutters, which will reproduce whatever they are asked to in pretty much any colour you like, including metallics.
The only question in my mind is how small a font they can handle successfully.
dseymo1 is offline
Old 22nd Dec 2016, 8:50 am   #3
Nukeybrown
You could try your hand at screenprinting
Nukeybrown is offline
Old 23rd Dec 2016, 10:18 pm   #4
OscarFoxtrot
OscarFoxtrot's Avatar
Try
http://www.drytransfershop.co.uk/ (rubbish website)
or other railway modelling suppliers do very small transfers
OscarFoxtrot is offline
Old 19th Jan 2017, 8:51 pm   #5
Bazz4CQJ
Bazz4CQJ's Avatar
Hi
any progress on this? Useful to know.
Wonder if this guy might consider this requiremnt http://www.ebay.co.uk/itm/1814623939...%3AMEBIDX%3AIT
(no connections).
B
Bazz4CQJ is offline
Old 20th Jan 2017, 3:52 pm   #6
skodajag
I've explored several options, along the lines of the helpful suggestions here, but all seem rather labour intensive with no guarantee of success. Although there was nothing very elaborate about the original application of lettering, even slight deviation from the original appearance quickly looks wrong. You know how it is: if you notice it, it probably means it's wrong whereas if you don't it probably means it's right.....So I'm trying to keep the original lettering and touching in where necessary.
skodajag is offline
Old 21st Jan 2017, 1:18 pm   #7
Argus25
No Longer a Member
The solution to the problem is Gold Letraset. You will have to hunt around on ebay to find the size and font that you prefer. It is becoming less common it seems, in the past the last lot I got was from Spain. It is best applied before the panel receives the final coat of varnish or polyurethane. I have used this extensively in prewar television restoration with great success and it looks just as good as the original.
Argus25 is offline
