Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > General Vintage Technology > Where To Get Sets and Parts
Where To Get Sets and Parts For discussions about swapmeets, rallies, NVCF and BVWS, car boot sales, antique and charity shops, dealers, newspaper adverts, the local tip and just about any other source of equipment (other than eBay).
Old 16th Dec 2016, 3:57 pm   #1
Oldcodger
Default Maplin PCB
For anyone who uses 100mm X 75mm or 160mm X 10mm PCB, (Pre sensitised, but at the price it's worth getting it to remove the spray) try Maplin codes JP56L and JP55K, now at 22p in the few stores that still have stock.
Oldcodger is offline
Old 16th Dec 2016, 4:21 pm   #2
MrBungle
MrBungle's Avatar
Default Re: Maplin PCB
That's a pretty good find. Thanks for the heads up. I'm in Staines at the moment and they have one in stock. Not for long!
MrBungle is offline
Old 17th Dec 2016, 12:14 am   #3
David G4EBT
David G4EBT's Avatar
Careful what you wish for - it's not FR4 glass fibre board - it's cheapo SRBP laminate (synthetic resin bonded paper).
Fine for simple projects and often found in cheapskate domestic electronics, but personally, I only ever use FR4 woven fibreglass resin board. ('FR' stands for Fire Retardant). The only place I used SRBP is for front panels for projects and at the price, it's well worth it for that. (There are those who seek out SRBP, as they do mustard caps, to make 'authentic' replicas of guitar modules such as 'fuzz boxes', but let's not go there).
https://en.wikipedia.org/wiki/FR-4
FR4 isn't expensive to buy and neither is negative UV photo-resist dry film to use with it.
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is offline
Old 17th Dec 2016, 12:59 am   #4
Oldcodger
BUT- at 22P - it's cheap, and for some folk might be just what they want. I remember in the old days of GEC where they threw out large sheets of Fibre PCB, because it hadn't taken the photo, and we got it for nowt.
Old 17th Dec 2016, 8:50 am   #5
MrBungle
MrBungle's Avatar
SRBP is fine for most amateur projects. FR4 is a pain to cut, eats drill bits and the dust off it is hazardous as well.
MrBungle is offline
Old 18th Dec 2016, 10:48 pm   #6
Oldcodger
It also sorts out the pro with a soldering iron from the amateur that's a bit heavy handed. Fibre takes heat a lot better than SRBP, so tracks don't lift easily( possibly why firms like it).
