4th Dec 2016, 9:02 pm | #1 |
All World two help.
hi
I'm about to put the parts together to build the All WORLD TWO. Only I need help with the coil for it. Dia - turns swg. please help. Pete G4MRU hI Again. I've been looking at the information on here.. Good but nothing about the coils... pete Last edited by peter.sables; 4th Dec 2016 at 9:24 pm. |
4th Dec 2016, 10:57 pm | #2 |
Re: All World two help.
There's a 73-page paper by Gerry O'Hara at the Eddystone User Goup on the 'All World Two' at the link below Peter, but originally the coils were off-the-shelf Eddystones, so unless you can find the data about those coils, that's not a lot of help. Undoubtably others will have built replicas, so if no-one on here can add anything, you might like to try your luck on the EUG:
http://eddystoneusergroup.org.uk/Res...Appendices.pdf Hope that helps a bit. Good luck in your quest.
4th Dec 2016, 11:21 pm | #3 |
Some info here for some coil turns, no diameter given as far as I can see but should be able to work out/guesstimate ?:
http://www.vintageradio.me.uk/kits/eddy_allwave.htm Lawrence. |
5th Dec 2016, 12:07 am | #4 |
hi.
thats good. I can make a start with that. pete G4MRU |
5th Dec 2016, 12:00 pm | #5 |
Hi Pete, I have this 1.5" D coil, Looks like its the same former on the above Eddystone page with 6 pins, marked "RAYMART MFC CO BIRMINGHAM" Box is marked looks like "281L coil for radio" or may be price 28/4 but that would be very expensive for the year. Yours for postage if needed.
John. Last edited by 60 oldjohn; 5th Dec 2016 at 12:08 pm. |
5th Dec 2016, 5:21 pm | #6 |
HI.
Yes please. That's brilliant Pete G4MRU |
26th Dec 2016, 9:58 pm | #7 |
Hi Pete
Dia is 1 3/8" all the info can be found on http://www.eddystoneusergroup.org.uk/ I've attached a pic of the data, I hope I need a 10x14 pf step bandspread tuning cap 'tank unit 1042' for a similar project [amateurs SW2][ Cheers John G8JMB |
12th Mar 2017, 5:21 pm | #8 |
Hello Pete,
Are you using Eddystone formers and did you find the turns count information you needed? 73, Lou VE3AWA |
13th Mar 2017, 12:33 am | #9 |
I wonder which is better; an "All World Two" or an "International Shortwave Two" (for latter see http://vintageradio.me.uk/radconnav/2_valve.htm) ?
Perhaps we should ask Harry Hill? Some similarity of coils? B
24th Mar 2017, 10:30 pm | #10 |
hi.
I have finished the All World Two. People keep asking is it any good. I must say I've built better. Its all down to getting used to the band spread. In mine I used a modern tuning capacitor. Trouble is the are not linear, so the band spread is not linear. not good. Pete |
25th Mar 2017, 9:25 am | #11 |
Given the limited degree of selectivity of a two valve TRF, and if you have some decent slow-motion drives, I'm a little surprised that you need bandspread, at least for broadcast stations. The "Int. SW 2" didn't have bandspread. Perhaps those Eddytone formers really do make super Hi-Q coils .
B
25th Mar 2017, 10:03 am | #12 |
25th Mar 2017, 10:48 am | #13 |
Here's a good article on regens from 1933:
http://www.rfcafe.com/references/qst...y-1933-qst.htm Lawrence. |
27th Mar 2017, 10:50 pm | #14 |
hi
That is the problem. Ha the band spread is 25pf. pete |
