Old 3rd Dec 2016, 12:57 am   #1
Oldcodger
Default Pulse Dial Speed Checking.
NOT a very accurate method, but possibly helpful to newbies is the old tried and tested in the field method. I found it reasonably accurate on the older types of Strowger exchange. But that was after I'd calibrated my self against a dial speed tester.
1) Insert finger in "0" hole.
2) Release dial and start counting at a resonably pace -100 1000 and1. Dial should stop when you reach the last ( i.e 1 digit, approximately 1 sec after dial release( but this was done in the field) in the days when watches were not exactly reliable on second timing).
Most possibly familair to ye ancient GPO/PO(T) blokes).
Oldcodger is offline
Old 3rd Dec 2016, 7:30 am   #2
TonyDuell
Default Re: pULSE DIAL SPEED CHECKING
Yes, I do that when looking at second-hand telephones in junk shops, etc. It gives a good idea if the dial is running at about the right speed, or if it is gummed up and running far too slowly.
I am told that these days you can sample the dial pulses with a computer+soundcard and look at the speed. Personally I either use a Tester 422/1 if I need it approximately, or a logic analyser to get it accurately. Mainly because I have both on the bench anyway.
As an aside, a friend of mine bought a German telephone. Tucked inside the dial mechanism was a strip of paper which turned out to be a pen recorder trace of the dial pulses (presumably from the time the thing was made).
TonyDuell is offline
