26th Nov 2016, 7:31 pm | #21 |
Re: square-waves from a chip other than NE555, please?
Wonderfully interesting and helpful contributions , thank you all! One things is the 'chicken and egg' nature of the application - I know the approx required operating frequency to within 150KHz but I won't know exactly until empirically , when I run the big oscillator attached to the PLL!
Al |
26th Nov 2016, 7:53 pm | #22 |
Re: Square-waves from a chip other than NE555, please?
I think the Vellerman kit uses a 555, but doesn't have a decoupling cap on pin 5 ? I found that the frequency drifted with the changes in the battery supply voltage which wasn't good for the application I wanted it for. regards Peter B |
26th Nov 2016, 8:35 pm | #23 |
Sure it will! The control voltage inside the chip is around 1/3 of the volts on the power supply, so this is an inherent property of the chip. It is fine with a stabilised power supply ...not to go too far OT
Al |
26th Nov 2016, 9:54 pm | #24 |
It depends on how it's wired up. Using the standard astable circuit, it's reasonably good - less than a percent per volt of supply voltage change IIRC. The two thresholds are linked to the supply (1/3 and 2/3), but the charging currents are proportional to the supply. The equations that determine each of the time periods do not have the supply voltage in them.
26th Nov 2016, 9:57 pm | #25 |
Personally, I agree
And the various adaptor boards which can be found cheaply are really good for those who prefer conventional construction. SOT23 is not too small to deal with, given strong light and perhaps some magnification if needed. Today, a lot of the interesting new products are SMT-only. Many big manufacturers have stopped making the TO92 package, which is a sign of things to come. |
27th Nov 2016, 12:26 am | #26 |
The only problem with surface mount is prototyping and low power handling capacity. I still haven't worked out a good solution to the first problem. The second problem occasionally throws a component at my eye on power up. The little 0802 LEDs go off like flame throwers.
Back on topic, take a look at: http://www.americanradiohistory.com/...PW-1974-01.pdf pp853 on astable circuits. Amazing how far you can take a few transistors. Last edited by MrBungle; 27th Nov 2016 at 12:31 am. |
27th Nov 2016, 1:21 am | #27 |
Why not use the CMOS 4060? It has both an oscillator and a ripple counter thzt cn be used as a divider.
27th Nov 2016, 1:27 pm | #28 |
That's a really good idea. I've used a couple of them in clocks in the past. 32.768KHz watch crystal gives 2Hz out as well which is really handy.
4th Dec 2016, 1:16 pm | #29 |
Use a CD4060, it has a CR cct and divider to allow a range of values and times. Often used as a long delay timer.
7th Dec 2016, 12:37 am | #30 |
No Longer a Member
Do you have an Android tablet or smartphone?
I use an app to provide signals to put through devices. https://play.google.com/store/apps/d...enerator&hl=en This one has all the bells and whistles. Dual channel. Phasing. Modulation. Square. Sine. Triangle. Noise. The works. I needed to cut down on gadgets. I was tempted to get a function generator or build a circuit but now there is no need. Time saved for fixing things. |
7th Dec 2016, 1:50 pm | #31 |
Update : I nearly went for David G4EBT's solution - thank you, David , a handy little CMOS chop you're recommending in this package, definitely one to come back to ,and I appreciate the effort that went into your post . The applet is very useful , too.
In the end , I'm going instead for a dedicated PLL, the CD4046. This has a VCO good to the 1.3Mhz I need, as well as some other features that make it attractive in this application . I've learned a lot about the various choices on this thread , and I will make time to study some of the device me mentioned and try them out . JayBee66, yes. There are some nice little apps out there and I have one called Signal Gen. These are indeed useful for for audio frequencies, and I will be modulating the cathode (filament centre tap ) of my big triode-connected pentode via the output of this, through isolation circuitry . The frequency I need for this is very low, so the app is ideal. The original post was more directed at RF-capable ideas. Thank you though.
Al Last edited by Al (astral highway); 7th Dec 2016 at 1:56 pm. |
3rd Jan 2017, 8:51 pm | #32 |
Ah, but is not to be confused with the Phillips HEF40106BP? (which is what turned up when I ordered using '40106' from EBay). The HEF40106 device operates at approx 1/2 of the expected design frequency using the applet you kindly resource here..
So with 47pF pin 1 to ground and R 12K, I'm getting a nice clean square wave but approx 750KHz.
Al Last edited by Al (astral highway); 3rd Jan 2017 at 8:57 pm. |
3rd Jan 2017, 11:46 pm | #33 |
Come late to this one, otherwise I'd ask if anyone has a copy of Electronics circuit design Winter 1980 ( Part 1/2 -I don't know to pass on to the OP) ,but it's got a brilliant section on both CMOS Astable and Monostable circuits, most using either 4001/4011, and a few other components. Monostable timings are given, but few details on the frequencies outputed, but that could be derived on breadboard.
Couple of circuits that might interest the OP. Both uses either 4001 or 4011 ,a resistor or two and a capacitor. cAN POST UP THE CIRCITS IF INTERESTED. Last edited by Oldcodger; 3rd Jan 2017 at 11:53 pm. |
4th Jan 2017, 10:05 am | #34 | |
Just to keep this on track, I'm interested in devices, rather than circuits, thank you, so please don't worry about posting the article from PW. Also, I'm only those that are RF capable and rock solid at greater than 1MHz. Atm, I'm most interested in any comment on post number 32... Thank you
Al Last edited by Al (astral highway); 4th Jan 2017 at 10:17 am. |
4th Jan 2017, 10:40 am | #35 |
Just out of interest, have you considered the VCO block in the 74HC4046?
If you're building a PLL, that's pretty much a canned device. It's same functionally as the 4046 but a hell of a lot more stable and will kick out a few MHz quite easily. Also the MC145151P, still available from Spectrum Communications is pretty nifty. And then there's the DDS route. Cheap AD9850 boards will deliver a nice square wave that is frequency locked. |
4th Jan 2017, 1:32 pm | #36 | |
En route, I'm investigating some other chips as RC controlled oscillators, just for my own enlightenment. The note I made yesterday on the 40106 was because before I work out the PLL's RC values, I'm separately constructing a high powered oscillator with a big RF output to test the exact operating frequency of two very large inductors that are close coupled - so physically large that they will swamp the feeble output of low-powered signal sources. This is just a deviation from the main goal, but a necessary one. Hope that clarifies things!
Al |
4th Jan 2017, 2:17 pm | #37 |
I see! A collection of other square wave sources for consideration off the top of my head:
1. 566 VCO - nearly unobtainable for a reasonable amount of money. 2. Ignoring the topic title a bit, but the 555. The CMOS 7555 version from Intersil isn't too bad. Standard bipolar ones are horrid. To correct the somewhat wonky duty cycle, run it at 2x the desired frequency and then through a 74hc74 as a /2 divider. Good to 2.5-3MHz. 3. 74hc14 - pretty stable due to low bias current. Nice xtal, RC and with some playing around, LC oscillator. 40106 is usable but not as fast and they blow up if you look at them wrong. 4. 74hc4060 and 74hc390 chain - I've got one of them on the bench now dividing an 8MHz crystal down to 500, 50, 5 and 0.5 Hz for a frequency counter timebase with stable duty cycle and good rise times. The HC4060 will run from an RC oscillator absolutely fine. 5. MAX038 - good to 20MHz. Technically a function generator but will kick out a nice square wave. 6. XR2206 - good to about 1-2MHz. Also a function generator. 9. LM311 or equivalent comparator can be configured to kick out a square wave. In the on state, the capacitor charges via the feedback resistor. In the off state, the capacitor discharges via the feedback resistor. A good low bias current one is quite frequency stable. I'll probably think of more later. Really though, if you want RF that means frequency stability which means LC or Crystal based circuits. From the above, they can be derived. I'd probably go for a tuned LC colpitts and drive a few big class C stages with it then stick a low pass on the output if you want big RF power. If you can put up with a few tens of Hz drift that's probably easiest. |
4th Jan 2017, 10:09 pm | #38 |
Hi Al, following on from Mr Bungle, look up comparators, a version of the op-amp but normally with an open collector output.
A vast number of devices to choose from, some of which will operate up to 100MHz. Ed |
5th Jan 2017, 10:46 am | #39 |
Make sure you have some hysteresis though as the fast ones go nuts otherwise with the tiniest bit of noise:
[img]http://i.**********/0KcXo3P.jpg[/img] |
5th Jan 2017, 2:48 pm | #40 |
Out of curiosity I've just spragged together a resistor and capacitor to a 74HC14 per the circuit I posted at post #10 above.
As I said then, a square wave generator doesn't get any simpler than an IC a resistor and a cap. I didn't make any attempt to shorten the wiring, just a 50pF cap that happened to be to hand, and a 22k resistor, the frequency coming out at 1.352MHz. Not a perfect square wave, as can be seen from the rise time and mark-space ratio, but clean, and not bad considering it's just tacked together. (about 4V p-p). I'm a simple soul so simple solutions are what I go for - complicated stuff is beyond my wit and above my pay grade - small things amuse small minds!
