15th Oct 2016, 6:16 pm | #1 |
Cheap stick-on feet
Instead of buying expensive "proper" feet for project boxes, I buy the cheap stick-on "bumpers" in large packs from DIY stores or supermarkets. They work equally well and come in a variety of sizes. I believe they bare sold to deaden the noise of kitchen cupboards etc closing.
Alan. |
15th Oct 2016, 6:37 pm | #2 |
Re: Cheap stick-on feet
Good idea. A lot of those outlets sell proper stick on feet too. Not forgetting the stick on felt pads that you can put on the bottom of 30s sets to stop them scratching cupboards and tables.
15th Oct 2016, 9:26 pm | #3 |
Or the nail on felt pads in metal cups that don't fall off, B&Q I think.
16th Oct 2016, 8:14 pm | #4 |
Needing to replace the rubbers on a PC box I used four of those 1 3/4 inch tap washers that skull about in the kitchen draw, fixed on with (H)ev(h)o Impact adhesive. Works a treat
Anton Golf Three Very Fine Business Member of RSARS and PARC |
17th Oct 2016, 6:58 pm | #5 |
Tap washers are a good trick: there is a domed type [usually called a "holdtite" washer] that I've used in the past by pushing them over the short stub-end of a 2BA machine-screw screwed through from inside the case you're fitting them to.
A pack of ten 3/4-inch [bath-tap size] ones costs about 60p if you know where to look. |
17th Oct 2016, 7:22 pm | #6 |
Wilko did a great range of self-adhesive bumpers, pads and so on, including cork and felt ones too. But certainly in my local branch, they've all but disappeared.
18th Oct 2016, 3:29 pm | #7 |
Thats a shame, I used to have a great shop back in north Yorkshire that sold all sorts of handy DIY and those little gel stick ons and the felt feet were absolute godsends for use as feet on small and not so small equipment housings. Boyes for those of you in the Northeast still.
B&Q do a good range but even with a Clubcard discount I find them to be not the cheapest around. Handy though. Andy. |
18th Oct 2016, 5:00 pm | #8 |
ESR components actually do sheets of proper sticky rubber feet quite cheaply, if you want the genuine article. No connection with the company other than a satisfied customer.
20th Oct 2016, 11:23 am | #9 |
I used to have a busted tractor tyre inner tube I got from the local tyre place. I used it to make rubber feet.
21st Oct 2016, 6:23 pm | #10 |
Now I like that solution David. You could make thousands of feet from a tube that size. I suppose you could use a leather hole punch to make them, as cutting them out with scissors or a knife could be a bit tedious.
7th Dec 2016, 12:30 am | #11 |
No Longer a Member
I get old electronics through FreeCycle and peel the old feet off.
I also get spare components that way too. |
