20th Feb 2017, 10:29 pm | #1 |
Philips N7150 Reel to reel
I have Philips N7150 which plays back well on all tracks on recorded tapes but when in recording mode, although the level meters show a good response and the tape erases, playback is blank. This is true for microphone and direct record inputs. I am an experienced radio and hif repairer but have limited knowledge on tape machines. Have a full range of test equipment and the German service manual. Any hints on where to start to get this mechine recording would be most appreciated.
20th Feb 2017, 10:35 pm | #2 |
Re: Philips N7150 Reel to reel
Try cleaning the heads with IPA or meths. I have found it only takes a hardly visible amount of dirt on the recording head to inhibit its function. Hope that's of some use.
20th Feb 2017, 11:23 pm | #3 |
Thank you, will try tomorrow and get back to you
21st Feb 2017, 10:18 pm | #4 |
Now records on one channel but very low volume
21st Feb 2017, 11:39 pm | #5 |
I can only suggest you have another couple of goes at cleaning the heads. It takes hardly any dirt to inhibit recording. Also source/monitor switches can often cause problems. try repeated operation with switch cleaner squirted into the switches.
