Old 13th Jan 2017, 12:04 am   #1
els1967
Default GPO Dial
Evening all. In some over enthusiastic restoration of a dial I managed to crush and shatter the little tube that is used as an insulator to jumper out speech ctt. on the phone on the dial contacts. I've put a circle around it in my picture.
Does anyone know what an earth it's called and where I get a replacement? I presume it's simply some sort of plastic tube I could cut to length? Or something?
Thank you.
els1967 is offline
Old 13th Jan 2017, 5:10 pm   #2
Electric
Electric's Avatar
Default Re: GPO Dial
Might sound a bit naff, but in the past I have used a bit of stripped wire sheathing cut to length in desperation.
Hope this Heath Robinsoness helps.
Electric is offline
Old 13th Jan 2017, 7:39 pm   #3
Euros1951
Switching lever buffer. Does this link help?
http://www.britishtelephones.com/tel%20auto%20b5125.htm
Euros1951 is offline
Old 14th Jan 2017, 1:26 pm   #4
els1967
Thanks for the tips.
Just seems a bit odd to me that there isn't any info in the n-diagrams since the GPO seemed to be so good at documenting just about anything that moved.
els1967 is offline
Old 14th Jan 2017, 6:28 pm   #5
Pellseinydd
'N' diagrams are the circuit diagrams of subscribers apparatus and ways of connecting it up. Adjustments and breakdown of components was always in TI's originally, then in EI's from c1930 then back to TI's c1969/70.
Pellseinydd is offline
