Sets and Parts Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps. |
27th Mar 2024, 12:18 pm | #1 |
Knob for Colvern potentiometer with short shaft
Can anyone please help me with finding a suitable knob for Colvern multi turn potentiometer. I tried around six different knobs, but the shaft is too short for the k grub screws to attach to. Are there special knobs designed for this type of potentiometer ?
27th Mar 2024, 12:28 pm | #2 |
Re: Knob for Colvern potentiometer with short shaft
A collet knob might suit your needs. If the shaft is at least as long as its diameter, this type of knob will be suitable. You will need to know the shaft diameter, probably either 6mm or 1/4".
PMM |
27th Mar 2024, 12:29 pm | #3 |
Post crossed!
Collet fixing would probably suit. Loads of different styles available. Need to know the shaft diameter and diameter/ height of knob you require for anyone to be able to assist you. Rob
27th Mar 2024, 12:47 pm | #4 |
Thanks for the replies. I have attached a picture of the pot in its intended housing .The shaft diameter is 6.25 mm and it is only 5 mm long.
27th Mar 2024, 1:45 pm | #5 |
Hi Jolly - perhaps that was designed as a posh preset trimmer type of potentiometer, with the screwdriver slot and pitifully short shaft, and never intended to have a knob fitted? I have come across similar, but single-turn pots behind the panels of some old AVO test equipment.
Cheers Chris |
27th Mar 2024, 2:02 pm | #6 |
I agree, there were caps available (Like a valve cap) to finish them off and deter fiddlers.
My favourite text message "I'll be there in five minutes, if not read again" |
27th Mar 2024, 2:13 pm | #7 |
It's too nice not to use if you have an application requiring a knob, so perhaps some form of "shaft extender" would be a viable option? And a bit of mechanical ingenuity in the mounting arrangement to allow the longer shaft to fit through the necessary panel. Good luck.
Cheers Chris |
27th Mar 2024, 3:31 pm | #8 |
Two suggestions:
1 Countersink the knob so the potentiometer circlip does not prevent the knob going on to the shaft quite so far. 2 If you have access to a belt sander/linisher remove some material from the knob so the grub screw is right at the bottom. |
27th Mar 2024, 5:21 pm | #9 |
Thanks for the further replies. It's a really nice wire wound pot I bought off the forum and comes in very handy for the test bench.
I have now implemented a temporary solution using a plastic knob from a broken stereo. Using a step drill I carefully got rid of the D-shaped cavity inside the knob till I ensured that the pot shaft was going deep enough inside. I then put some hot glue inside the cavity and pressed the shaft into it, holding it tight for a couple of seconds. The shaft is now rotating freely along with the knob. I am not sure how durable this solution is, but I can always look at the other suggestions provided if my solution fails. I don't intend to use the pot elsewhere, so a semi-permanently glued knob is fine. |
28th Mar 2024, 11:01 am | #10 |
I've dug out four knobs that might fit, all fit a similar Colvern pot to yours. They either have deep skirts or low grub screws. Yours for cost of postage - £3.
Drop me a PM if interested, Andy.
28th Mar 2024, 11:55 am | #11 |
If needed, I have some black collet knobs here which should get a very good grip on that length of shaft. FOC.
28th Mar 2024, 7:46 pm | #12 |
28th Mar 2024, 7:47 pm | #13 |
