Television Standards Converters, Modulators etc Standards converters, modulators anything else for providing signals to vintage televisions. |
23rd Jan 2021, 4:38 pm | #1 |
Pin out for JVC modular PM58054M
Hello
I have a JVC modulator PM58054M part and would like to find out which pin if which for connecting it. I dont have the VCR and would like to use the modulator for connecting it to a French 625 line TV here are some photos It seems to have 2 integrated circuits. These circuits are probably well know but as the ICs are adjacent to other circuitry it is not possible to read the model number of the ICs I want to make sure i apply the voltage to the correct pin to avoid blowing up the ICs. It would also be good to know what voltage to apply. If i know the pin number for the voltage i can probably work out the other pins. Thanks Thierry
BVWS Member. |
23rd Jan 2021, 5:58 pm | #2 |
Re: Pin out for JVC modular PM58054M
I have a lot of JVC manuals, it should be easy to find pin outs from that, I don't recognise that modulator but by looking at the manual it would make it a doddle.
23rd Jan 2021, 6:01 pm | #3 |
Normally they work on 5v, but can't you extract video and audio from the appropriate sockets?
23rd Jan 2021, 7:00 pm | #4 |
Thanks. I've just found some written characters hidden below the connector. AGVBGB !!
It seems to work best on 8/9 v Thanks Thierry
BVWS Member. |
23rd Jan 2021, 10:03 pm | #5 |
Here you go. That style of modulator with slight changes was used in a large number of JVC machines and their clones in the UK. I encountered them in the Ferguson 3V44 onwards up to early FVxx models.
Do you know where the modulator came from? If it's from a UK machine it's output will be PAL-I and will not be of much use with a French SECAM-L TV unless it's a multistandard set. Googleing that part number didn't bring up any results. PU58054M does bring up a couple of hits but I can't tell what system they're for. John Last edited by jayceebee; 23rd Jan 2021 at 10:23 pm. Reason: PU version of part number info |
23rd Jan 2021, 10:41 pm | #6 |
excellent, thank you. Found it in France to repair a French TV in the UK
Thierry
BVWS Member. |
