Old 18th Nov 2017, 4:43 pm   #1
vectracman
Default Fidelity HF41
Hi
I've got a Fidelity HF41. I need help to Identify what amp would be used in this Machine, as I can not find any info.
ID:	152451   Click image for larger version
ID:	152452   Click image for larger version
ID:	152453   Click image for larger version
vectracman is offline
Old 18th Nov 2017, 5:58 pm   #2
AC/HL
AC/HL's Avatar
Default Re: Fidelity HF41
There seems to be little information about this player, even though thousands must have been made. As far as I can see, it was a basic two valve design, similar to most players of this type. The cartridge and stylus also appear to be missing, although it's quite probable that it would be faulty by now.
AC/HL is offline
Old 18th Nov 2017, 6:11 pm   #3
Edward Huggins
Although looks like a transistor model, I think it's a valve unit using UL84/UL85 and the was the last Fidelity made using valves. To be sure, you can easily check to see if it has any hum when the volume is on full and if it gets warm after after 3 minutes. You are clearly going to need a cartridge for this. If you are planning to restore this and use it, what experience do you have of repairng these old players? If valved, this will have a"live" chassis.
Edward.
Edward Huggins is offline
Old 18th Nov 2017, 6:15 pm   #4
ukcol
ukcol's Avatar
Can you post an internal picture of the amplifier chassis (or board) ?
As Bill says there seems to be little info on this model.
However, it is possible it is not a valve amplifier. By the time Fidelity got to model HF37 they were using a discreet transistor amplifier and models HF42, HF43 and HF45 use an integrated circuit amplifier.
ukcol is offline
Old 18th Nov 2017, 6:26 pm   #5
vectracman
Hi
There is no amplifier chassis just screw holes on the back of the front panel.
Old 18th Nov 2017, 7:43 pm   #6
Nuvistor
Nuvistor's Avatar
Even if you can identify the amp you will be very lucky to find one. You could fit a transistor or IC amp plus PSU and new cartridge to get it working but I would make sure the deck is in working condition or can be made so before doing any other work on it.
Frank
Nuvistor is online now
Old 18th Nov 2017, 8:21 pm   #7
ukcol
ukcol's Avatar
I hadn't understood from your first post that the amplifier was missing completely, that does make things rather difficult.
ukcol is offline
Old 18th Nov 2017, 9:21 pm   #8
Edward Huggins
Aghh - I didn't twig this either! I suggest you fit a Mono IC module and that will allow you to use a (still available) medium output cartridge.
Edward.
Old 20th Nov 2017, 8:48 am   #9
vectracman
I have got a UL84/UL85 valve amp , So I think I will fit that valve amp and change the speaker as its only 3 ohms . Sound better than transistor amp.
Thanks
Old 20th Nov 2017, 9:47 am   #10
Nuvistor
Nuvistor's Avatar
Why change the speaker, your UL84 amp was probably designed for 3 ohms. Not sure it will sound better than a transistor amp, the single pentode valve amps were not known for quality. You will also require an expensive high out put cartridge.
A UL84/UY85 amp will probably be live chassis, if you go down that route build in to the player all required safety features to eliminate any possibility of electric shock.
Frank
Old 20th Nov 2017, 10:29 am   #11
ukcol
ukcol's Avatar
i Frank
I don't think it has been established that the original amplifier was a valve type and given that Fidelity had gone for a transistor amp by the time the HF37 came out the chances are it was a transistor or IC amplifier.
ukcol is offline
Old 20th Nov 2017, 10:50 am   #12
Herald1360
Herald1360's Avatar
Perhaps not as "discreet" as the amp in this HF41
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 20th Nov 2017, 12:29 pm   #13
Edward Huggins
If I was wrong in my original surmize that this was valved and it is actually a transistor model, then the OP needs to check straight away that there is a 90V tap on the BSR motor to provide the valve heater voltage. The speaker will need to be 3 ohms, but there might be room for a bigger one e.g. 8" x 5". However, the overall limiting factor will be finding a high-output (and now very expensive) cartridge.
Edward.
Old 20th Nov 2017, 1:01 pm   #14
Nuvistor
Nuvistor's Avatar
Hi Colin,
There is a lot of unknowns with this, valve or transistor but like you I would think semiconductor of some sort.
I got the impression that vectraman just had a spare valve amp available and was going to fit that, that’s ok as long as he makes the live chassis safe, if he doesn’t know how to do that it is a major problem.
A small semiconductor amp with a transformer PSU and medium output cartridge is the way I would sort it out.
What do you think?
Frank
Old 20th Nov 2017, 2:03 pm   #15
ukcol
ukcol's Avatar
Yes, that would be the easiest way to proceed. It is not clear if the speaker is still in the player or not. Either way the speaker used will have to have a suitable impedance to match the amp of course.
ukcol is offline
Old 20th Nov 2017, 5:41 pm   #16
AC/HL
AC/HL's Avatar
This old eBay auction indicates that it's valve, although that can't be said to be definitive. Has any member come across one in the past, there must be quite a few knocking about?
http://ebay.net.ua/catalog/show/121518194606/
AC/HL is offline
Old 20th Nov 2017, 6:09 pm   #17
Stylo N M
yes i looked at that to bill, interesting, i wonder if they just did that as a one off, using a UY85 and a UCL82 valve, and used a medium output cartridge something like an X3M.
The reason it made me think that, is beacuse the deck is early 70's style, and they may of just been using up serpluss parts at the time.
But the thing is, if the amplifier is missing who knows if that is the correct deck, the key to that maybe as others have said, is there a 90v tap on the motor unit? (not much info on it)
Paul.
Stylo N M is offline
Old 20th Nov 2017, 7:12 pm   #18
Edward Huggins
Well, before I say I may have been correct all along, I will say that there were transistor versions of the earlier Fidelity HF35 which orginally used two valves. This transistor variant was chassis built (no ICs) almost like the valved version.
Edward.
Old 20th Nov 2017, 11:38 pm   #19
Stylo N M
I don't think you assumed anything wrong edward, it's just that theres very little information on this unit, you were quite correct in everything you gave in your input
Paul.
Old 21st Nov 2017, 12:25 am   #20
Michael Maurice
Michael Maurice's Avatar
One way to determine if its a valved or transistor model is to look at the motor and see how many wires it has.
If it has three wires then it was made for a valved model, the third wire feeding the valve heaters, if it has four wires then its a transistorised model. In this case the motor also acts as a transformer, the two white wires being the supply to the amplifier.
Forum Moderator
Michael Maurice is offline
