13th Oct 2017, 11:30 am | #121 | |
Re: Audiophoolery. 'Cable Break In' - I never knew that!
A cylindrical inductor is also a problem, since it is an RF antenna. At least one audio amp designer uses an air cored toroid for the inductor to overcome, at least to first order, this issue. And yes - loop stability is a big issue. Get it even mildly wrong and you can put an HF pole high Q at high hundreds of kHz to low Mhz that is lurking there ready to oscillate with the wrong cable and destroy the output devices. Lack of Zobels etc is alive and well - it was not just a feature of the 80's. Denis Morecroft's power amps have no output parts and no protection circuits (and are mounted in plastic boxes). And you have to use his speaker cables - two widely spaced wires - because a capacitive load is anathema to his designs http://www.dnm.co.uk/intro.html Craig Last edited by Craig Sawyers; 13th Oct 2017 at 11:39 am. |
13th Oct 2017, 11:31 am | #122 | ||
I once saw someone try to justify woven speaker cables by saying that earthing straps are woven, so therefore woven is good for RF. Quote:
13th Oct 2017, 11:36 am | #123 |
Anyone on this forum listen to music
Lawrence. Last edited by ms660; 13th Oct 2017 at 11:42 am. Reason: rearranged |
13th Oct 2017, 11:38 am | #124 | |
13th Oct 2017, 11:45 am | #125 | |
1. speaker impedances vary quite a lot with frequency 2. domestic speaker cables are electrically short at audio frequencies so no need to consider transmission line issues 3. at audio frequencies the characteristic impedance is nothing like the RF impedance For a low loss cable the characteristic impedance is sqrt[(R + jwL)/(G + jwC)]. At RF R and G are negligible (apart from causing some loss) so the characteristic impedance is approximated by sqrt(L/C). Unfortunately people see this and assume it applies at all frequencies. For most audio frequencies the correct approximation is sqrt(R/jwC): this is higher than the RF impedance, not resistive, and varies with frequency. Hence the idea of 'matching' an audio cable to a speaker is misguided. The only benefit of attempting it is that, perhaps by accident, the cable often turns out to have low resistance and that is what is actually needed. |
13th Oct 2017, 11:58 am | #126 | |
As part of another aspect of cable development I had a set of measurements taken for woven cables for differential and common mode transmission up to 1GHZ and RF pick up also to 1GHZ, at 3C test http://www.3ctest.co.uk/ . All as compared to the regular "kettle" lead. Since this was all under contract, I alas cannot share the detailed results. But you alas are wrong on this. Basically RF is picked up by the inductive component of a cable - so minimising inductance is a good goal to go for, and is proven by measurement. And the 14 ohm characteristic impedance is quite correct, and is an accident of the construction, not a design goal. Craig |
13th Oct 2017, 12:00 pm | #127 |
Oh - just to say we're away over the weekend from about now - so alas cannot reply to the inevitable firestorm I've created
13th Oct 2017, 12:34 pm | #128 | |
Cheers, GJ
http://www.ampregen.com |
13th Oct 2017, 12:37 pm | #129 | |
To avoid RF pickup what you need to aim for is symmetry and/or screening, not low inductance. Coax works because of the screen provided by the outer, and the fact that the outer and inner are concentric. Twisted pair works because of the frequent polarity reversals. Now it may be possible to design a woven cable which is almost as good as twisted pair, but why not just use twisted pair? Most people use untwisted pair quite successfully for speaker cables, but of course there is only little money to be made from untwisted pair as this is a commodity item. |
13th Oct 2017, 12:56 pm | #130 | |
We screened it as well as we could, but the laser light had to get out somehow, and the beams were approaching 40cm in diameter. So the wiring for our diagnostics had to be, um, insensitive to RF pickup. We could get away with good quality braided-outer co-ax over short runs relatively far from the machine. But cables which had to go any distance or run anywhere near the loud end of things had to be solid-outer. We liked Heliax a lot http://www.commscope.com/catalog/cab...s.aspx?id=1342. I've yet to see any used for audio. But maybe it's just a matter of time ... Cheers, GJ
13th Oct 2017, 2:14 pm | #131 |
Stevehertz, thanks for the comment, it's nice to be appreciated & I hope you enjoyed the website. I liked your analogy of ABX tests being garlic to a vampire.
Audiophoolery is one of those hipster trends which generally causes little harm - except to the 'phool's bank account - & provides a perverse source of amusement to pragmatic engineering types like me. However a particularly egregious outgrowth of this is the aquisition of vintage gear - particularly valve amplifiers - for the purpose of aquiring transformers & original valves. The 'phool considers a shagged out, low emission Mullard ECC83 wrenched from a hapless elderly PA amp to be a greater prize than a new high spec part because it's a 'black plate, yellow print' version presumably blessed with the appropriate amount of magic pixie dust & virgin's tears. As Lucien Nunes expressed his dismay at this practice earlier in this thread. Woe betide the valve amp collector, invariably outbid on the auction sites by 'phools desperate to liberate the aformentioned glass trophies & wound components from their metallic prisons. Hey! They're PA amps, guys! Not HiFi. You can't make a monoblock out of it. If I hear the word monoblock again, I think I'll scream. I think I'll take my medicine & have a little lie down now. Mark. |
13th Oct 2017, 3:27 pm | #132 |
Mark, all understood. However, just to throw a spanner into the works, in my other life I am a long serving guitarist - acoustic and electric. As you may well imagine, I have bought and used many different guitar amplifiers including expensive vintage models. For many years, I didn't believe that the valves in these amps made much, if any difference. One day, unhappy with the sound of a Mesa Boogie pre amp, I decided to swap the Chinese ECC83s for old (but tested good) Mullard ones. Now, you have to understand that what I am about to say refers to the sound when the pre amp is driven into distortion - as is normally the case with such a high gain guitar amplifier. With the stock Chinese valves in place the distortion characteristics were gritty, harsh, odd harmonics, thin - just generally nasty sounding. When I put the Mullards in, I could not believe the difference! It was, honestly, chalk and cheese. Now, the sound was sweet, 'choral', rich and meaty. So, just to be reiterate, I'm not commenting on how valves compare when run within their 'hifi capabilities', but certainly, when used in valve guitar amps in distortion mode, the difference is vast. And in that respect, I have over the years conducted many, many tests and comparisons and it has to be said, original Mullard ECC83s sound better than any other ECC83 valve. It's a similar story with other valves such as EL84s and EL34s. I don't know why, but there's definitely something about the construction of the original Mullards that makes them sweet sounding when driven into distortion in guitar valve amp.
This article may throw some light on it, and in any case it is interesting reading re valve construction: http://www.effectrode.com/signal-tub...al-comparison/
13th Oct 2017, 3:33 pm | #133 | |
13th Oct 2017, 3:42 pm | #134 |
Well yes, that's the easy, and with respect, obvious part. Craig seemed to hint at a much more 'high tech' version, here's what he said:
"Also mains cables need careful consideration to manage the junk that comes out our mains, particularly in these days of ethernet over mains. Once inside a chassis, that can radiate via anything that looks like an antenna. Mains filters a-la Shaffner are next to useless since they are only specced to operate up to 30MHz (or occasionally to 60MHz), and can often resonantly amplify interference at higher frequencies." There's also his follow up answer: "I specifically did not mention mains cable types; I have to declare an interest, since a range of EMC attenuating cables of my design is on the market on a royalty basis for prices that would make your eyes water. "I hesitate to mention a good alternative that sounds great, but is dirt cheap. I did on another forum and was excoriated so completely and repeatedly on the basis of safety that I quit the forum. So I remain stum on that - sorry."
13th Oct 2017, 3:52 pm | #135 | |
Cheers, GJ
13th Oct 2017, 4:01 pm | #136 |
Brilliant!
What worries me is that whoever thinks up this nonsense is busy thinking up the sequel (or should that be prequel these days) |
13th Oct 2017, 4:07 pm | #137 |
Well, that's one for the audiophools, not me, I'm not in any way, shape or form a 'cable freak'! On the contrary I have track record of boo-hooing high priced, audiophile cables for years. No, Craig suggested that there are ways to stop mobile phone hash getting into equipment via mains leads, that's my interest as he raises a good point if you read his post on the subject. Otherwise wet string (or if it's serious, bell wire) does for most of my hookups
A digital radio is the latest thing, but a vintage wireless is forever.. Last edited by stevehertz; 13th Oct 2017 at 4:13 pm. |
13th Oct 2017, 4:23 pm | #138 | |
Cheers, GJ
13th Oct 2017, 4:36 pm | #139 | |
Re: 'Cable Break In' - I never knew that!
Non-cryo-treated valves lack perspective and never realise how lucky they are, whereas those which have been to the North Pole are always thankful for the warmth of their filaments. Very interesting thread by the way. Liam |
13th Oct 2017, 5:04 pm | #140 |
Liam, you don't give a single, science or physics based reason why a cry-treated valve is better than an untreated one. I have to say, the use of phrases and words like 'character building', 'well rounded/superior sounding', and 'perspective' are exactly the reason why non-audiophools respond to such claims with phrases such as smoke and mirrors, voodoo and snake oil. I'd love to hear, from you, in your own science based words (not a link to someone else's similar 'beliefs') exactly why cry-treated valves are better? I don't believe they are until I see the proof, although you say quite clearly and knowingly, "This one is actually true". Prove it. And for sure, 'proof' isn't an audiophool telling me that they can hear a difference. I can't speak for everyone (clearly) but in general we're a pretty science based bunch on here, we grew up on electronics and radio theory, and we use that theory every day to repair, set up and even modify audio equipment old and new. Notional views are only of use to those who want to believe them and for whatever reason choose not to look for objective based answers. Then again... you could be joking..
