12th Oct 2017, 2:57 am | #81 |
Re: Audiophoolery. 'Cable Break In' - I never knew that!
Some would ask why I am building somebody else s amp design. I have designed and built many amps ( I cant remember how many) both vacuum AND sand, and even ventured into modern mosfets for a time.
WHY ? I used to own a small audio manufacturing business. I am NOT a brilliant engineer by any means, BUT I am extremely proud of my output transformers. Also my toroid design. I just happen to have an abundance of brand new, unused big fat output transformers, AND as it happens, a fairly large ready made supply of power toroids. Add to this a couple of hundred weight of passive components. I have retired from working mostly, except for a few repairs here and there for beer money. WHY will I build the Golden ears amplifier? I still love building stuff. I still build model aeroplanes ( yes balsa and tissue style) BUT I dont fly them. It keeps me off the street, and I derive huge pleasure from drilling and filing and soldering, then desoldering after discovering a better layout. At the end of the day, my kids will have a stonkin' amplifier to listen to, ( or do rock festivals with ). I have a seven watt amp at present that I have displayed here, and I almost dont use it at all. I still love my construction projects though!!!. To keep on topic, I use "modest" cables for inputs and outputs, BUT to buy anything that isnt directional or oxygen free copper is nigh on impossible these days. So speaker cables are about 4mm cross section, and after years of break in I still cant hear them, even if I jam them into my ears. These cables are perfectly silent!! Input cables are "matching" being OFC and directional. The speaker wire was about $1 / mtr Screened input cable about $2/mtr. I did try using twisted pair telephone cable but it hummed alarmingly, so I still use my hot pink directional input cables. These cables also dont make any sound BUT they did stop the hum. One thing I did do that was audiophoolery was to change the arm wires in my SME3009. I used Van den Hull cable. Cost about $50 for a half mtr. It DID improve the sound though, and yes I wasnt being deluded. Joe |
12th Oct 2017, 8:18 am | #82 | |
12th Oct 2017, 9:20 am | #83 | |
You've also hinted at the wider question of whether an 'accurate' hi-fi system matters, given the processing that the audio signals go through before we get our hands (ears ?) on them. In the early days of stereo the point was made quite often that the job of a hi-fi system was, first and foremost, to create an illusion. It may be that a strictly accurate system doesn't do that as well as one which in fact distorts the signal somewhat. If I fancied an evening listening to music at home then my first choice mght be to invite these ladies round, make some space in the living room and have them sing to me https://www.youtube.com/watch?v=OguVb3uSZTs. Sadly they're busy and I probably couldn't afford them even if they weren't. So I have to use two speakers and some electronics to try to create the illusion that they're there. That requires my brain to fill in a lot of gaps. That might be easier for it if the electronics and speakers have modified the signal to suit my brain's particular abilities. I was struck by dseymo1's account of exactly this experience. His brain suddenly created an acoustic 'image' that previously hadn't been there. Do you recall the craze, a few years ago, for those visual images consisting of a page covered in a highly repetitive pattern of what looked like tiny abstract shapes and colours ? When you first saw them there was nothing else there. But if you stared for long enough and you were in the right frame of mind a vivid 3D image would suddenly snap into existence, created entirely by your brain. I suspect that our brains are having to work pretty hard to create a 3D sound image using only the waves from two speakers. I therefore wouldn't be surprised if what an engineer would call a 'distorted' signal could sometimes do a better job of supporting the brain in that effort. Cheers, GJ
http://www.ampregen.com |
12th Oct 2017, 9:31 am | #84 |
No Longer a Member
There are actually some really good spin offs from the Audiophile industry.
Although original brand audio tubes have gone up in price, which is really annoying for those restoring vintage gear and trying to make it period correct, there were not enough valves to satisfy demand. As a result a number of valve making factories have cropped up worldwide, that otherwise never would have. Some of the products are actually pretty good. For example a while back I bought some new manufacture Tung Sol 6L6G's and some Ruby brand 5U4G rectifiers, and after subjecting them to a number of scientific tests in my lab, I was delighted to find they are every bit as good as RCA's original parts. Not only that the prices were very reasonable, unlike the originals. Also some good quality high voltage electrolytics and non electrolytic caps have been made recently too. So maybe like many things, there could be a silver lining to the Phoolery. It has created a renewable valve resource. If only the same thing could happen with CRT's. Hmm.. I'm sure I read somewhere that if you wire a monochrome CRT gun up as a triode amplifier it gives an amazingly clear picture of the sound, sort of bringing it into focus and illuminating it with a P4 moonlight like sound color. |
12th Oct 2017, 10:53 am | #85 | |
Cheers, GJ
12th Oct 2017, 11:42 am | #86 | |
12th Oct 2017, 1:49 pm | #87 | |
There is something better of course. I've just acquired one of these https://www.minidsp.com/products/min...minidsp-2x4-hd along with its matching calibrated mic. All I need to get now is that rarest of things - a round tuit ! Cheers, GJ
http://www.ampregen.com Last edited by GrimJosef; 12th Oct 2017 at 2:16 pm. |
12th Oct 2017, 4:24 pm | #88 |
I've got a similar thing, and it works a treat, again, with its calibrated mic. http://www.music-group.com/Categorie...EQ2496/p/P0146
12th Oct 2017, 5:38 pm | #89 |
Wow! This page feels like home! Thank you so much, David!
I use an alloy of gold, silver and palladium for all phono jacks and I use solid 4mm silver busbar with Teflon insulation for speaker cable. I can't understand people who use multi-strand cable as it obviously messes up the frequency response. Unfortunately, the alloy degrades after a month of so and I have to replace the jacks but the improvement in sound quality is astonishing. No smearing or jumping of signal for me and no horrible 'capacitance' in my cables. I am saving up to buy a solid ruby stand for my speakers as the bass response is a little off at the moment. I think it's the increased humidity with autumn arriving, obstructing the flux density of the sub-woofers.
Al |
12th Oct 2017, 5:42 pm | #90 |
Well, if multistrand cables smear sound where the strands touch each other in a bundle... and the atoms get aligned as the cable is broken in making the sound less edgy... and people can hear this sufficiently to part with lots of money and it makes them happy, then where ignorance is bliss 'tis folly to be wise!
I'm sure I get as much pleasure listening to my workshop radio (EF80 leaky-grid detector / PCL82 amplifier) as they do from their pre-conditioned oxygen-free solid core cables, single-ended triodes (cryogenically treated), all powered via gold-plated mains plugs with silver fuse cartridges. While I have a chuckle at their set-up, they'd likewise have a snigger at mine. And I'd concede that measurements would prove their system is superior! But who cares as long as we're both happy? GrimJosef and others have made a good point that those who like the 'valve sound' (even if it's just a constant-current load or cathode follower in a sand amplifier), while currently mopping up quite a lot of NOS valves and inflating their price, they have stimulated demand for continuing small-scale production. I'm waiting for the current trend for magic-eye level indicators to get someone restart build of EM80, EM34, TV4's... now that would be a success story! |
12th Oct 2017, 6:44 pm | #91 |
I wonder if a previously unexploited method of metallurgical analysis might be possible?
Firstly, a panel of audiophiles is played a standard sample of music derived from a signal which has been passed through each of a range of pure metal conductors. They note how each sample affects the sound. The standard sample is then replaced by the unknown alloy (presumably burnt-in to the same extent). Its effect on the sound should surely correlate with the 'known' properties of its constituents, in corresponding proportions. Well why not, if there's anything in these claims? |
12th Oct 2017, 6:55 pm | #92 | |
12th Oct 2017, 6:58 pm | #93 |
As far as the cable's concerned, I've always been an advocate (in theory) of twin PVC tubes (a bit like twin loudspeaker wire but with the copper all pulled out, and somewhat larger bore, maybe 6mm?) between amplifier and speaker. Then, you fill them with mercury.
No problem with atomic alignment; no problem with strand-to-strand smearing! Liquid conductor continually re-optimises itself! And to be honest, even with current price of mercury, still cheaper than phool-exotica! |
12th Oct 2017, 7:13 pm | #94 |
The tubes would have to be exactly the same length. Mercury delay lines are, I think, fairly well known. Any difference in the tubes would result in the signal to each speaker arriving out of phase with the other. But then what about the small but surely audible difference in timing between the axis and the radius of the mercury columns...?
12th Oct 2017, 7:29 pm | #95 |
Of course you wouldn't need to bother about cable quality if you linked everything up with bluetooth...
12th Oct 2017, 7:40 pm | #96 |
I thought mercury delay lines worked by sending a sound wave down a long, thin column of mercury?
12th Oct 2017, 7:44 pm | #97 | |
Regardless of that, I have often wondered what the "correct" audio is. Nowadays everything is recorded multi-tracked then mixed, equalized, compressed etc. so there is probably nothing available which sounds like what the musicians originally played. So why do you need clever cables etc. when the audio is so messed up anyway?
Stuart The golden age is always yesterday - Asa Briggs |
12th Oct 2017, 7:44 pm | #98 |
Replying to post 96: They do, but since when have audiophools bothered with facts?
12th Oct 2017, 7:54 pm | #99 |
I was thinking earlier and I came across the pinnacle of audio experience for me. It was a lowly NAD C340, 521 and some Tannoy Mercury speakers wired with 3A mains flex (from B&Q because Richer Sounds wouldn’t give me any free) and the interconnects that came with it.
A good friend came over and we did some psychoacoustic brain remodelling with a bottle of Smirnoff. This culminated in playing cricket with a poster tube and a rude stress toy with Pink Floyd’s High Hopes on in the background. That sounded absolutely amazing after half a bottle of vodka! Much cheaper than fancy wires even if you do feel like muck in the morning. |
12th Oct 2017, 8:00 pm | #100 | |
Exec summary: 1. No test is the same as extended listening at home where you are neither fatigued nor stressed nor are you troubled by the wrong choice of music or ancillary equipment. And since you are buying hi-fi to use at home no other test is nearly as important. 2. It is not practical to stage a double-blind test over a long enough period to avoid fatigue/stress yet still achieve statistical significance in anyone's home. 3. Audiophile claims are therefore untestable which means they have the status of 'belief' rather than 'science'. Cheers, GJ
