23rd Oct 2017, 6:47 pm | #401 |
Re: Audiophoolery. 'Cable Break In' - I never knew that!
Maybe you need stretched copper directional speaker leads and gold-plated connectors to appreciate the semitones thereof?
Regds, Russell W. B. G4YLI. |
23rd Oct 2017, 6:48 pm | #402 |
a) Rule, a thing for measuring.
b) Ruler, a thing for marking lines. I always use a slide rule to make at least one calculation in a design (I make it a personal 'rule', near enough for electronics!), my 12" Jakar sits on my desk at work much to the confusion of the youngsters. This is much more sensible than directional cables |
23rd Oct 2017, 7:04 pm | #403 | |
In my Younger days I experimented with home made tweaks that cost me nothing more than pocket money sums and a bit of Leisure time. The results were quite educational, and mostly disappointing. Now I am not saying I didn't get differences with some (and not that much) of my tweakery, but mostly that's all they were, "improvements" are too emotive and subjective for any rational discussion. Suffice to say I remain a sceptic but try to keep an open mind on things. And at least when or if someone else tries to convince or persuade me that I really should be using a particular construction of wire or a particular metallurgy etc etc etc, then my own (fortunately inexpensive) empirical findings stand me in good stead and keep both feet firmly planted on the ground. And here's a thing to ponder and I wonder if it's part of that phenomenon of "Psychoaccoustics", some days I can sit down and the music emanating from the stereo is utterly captivating and immersive and I hear all the little details and other musical clues that put the icing on my auditory cake. Then I can sit down in almost identical conditions, same kit same music, and I'm left feeling flat and cold by it all. So that alone suggests to me that a simple listen just doesn't work. Grim Josef hits it square on with his comment about the music in the listeners head, we all do it and that's why I can listen with pleasure to the old PYE transistor radio when I'm pottering outside just as much as when sitting comfortably with a nice cool beer and some nice music wafting over me indoors. Just my take on things. Andy. |
23rd Oct 2017, 7:05 pm | #404 | |
Martin
BVWS Member |
23rd Oct 2017, 7:05 pm | #405 | |
23rd Oct 2017, 7:13 pm | #406 | |
Martin
BVWS Member |
23rd Oct 2017, 7:30 pm | #407 | |
No, I think that many of the 'lost' audio companies went to the wall because they were started and run by engineers, not marketeers. All too often, the former think they understand and can do the job of the latter. A big and common mistake amongst engineers...
23rd Oct 2017, 7:41 pm | #408 | |
23rd Oct 2017, 8:01 pm | #409 |
Time to terrify the audio freaks with some (possibly) real data:
http://www.neumann-kh-line.com/neuma...?Open&term=TIM But maybe someone has already designed some cables which eliminates it. |
23rd Oct 2017, 8:10 pm | #410 |
It's alright, the advantage of three-speaker designs is proven by the graphology, so I infer that my Keesonic KBM's, which are four-speaker designs, are near enough perfect. No need for special cables.
24th Oct 2017, 2:55 am | #411 | |
No Longer a Member
It sounded so bad that I though there must certainly be an IC or transistor bias failure or component failure. I got the scope on the low level signal, and it appeared exactly as though the audio signal had been half wave rectified. It turned out that oxidation in the pcb plug connector pins was the cause and a diode had created itself there. Because it was audio though I could hear this anomaly, but it did make me wonder if it had been another type of circuit, like a logic circuit, it still might have kept apparently working and I'd be none the wiser or perhaps an intermittent fault. Now I treat nearly all my pcb connectors with wd40. |
24th Oct 2017, 5:56 am | #412 |
We used log tables when I was at school; but my Grandad left me his "NOS" Jakar No. 29 slide rule, and I do use it occasionally for a quick multiplication, division or square root. It has measuring scales down to 1/32 inch, but only whole millimetres.
24th Oct 2017, 10:01 am | #413 |
24th Oct 2017, 12:41 pm | #414 | |
Not unreasonable- half a millimeter is about 20 thou. Somewhat less than 1/32" at about 31 thou. Depending on the material and engraving, at some point the designer would need to draw the line
25th Oct 2017, 12:06 pm | #415 |
The 'poor contact' distortion doesn't just affect low level signals.
A few years back I bought a ‘for repair’ amplifier on ebay for peanuts as I wanted something for the workshop. There was a trivial fix in the preamp and all was good! A while later, listening to the radio, I became aware of some quite slight but noticeable ‘distortion’ coming from one speaker - sounding like a little more sibilance from one side. I swapped speakers etc and pinned it down to the power amplifier. With a watt or two of power, I measure something less than 0.3% distortion on the iffy channel (a noisy looking residual and maybe 100x worse than the other channel). It turned out to be a dry joint on the output inductor and had probably been like that from new! I was surprised both at the cause and the fact that I could hear it straight away on (mono) speech but I could not, in all honesty, say I could hear the distortion on reproduced music … dc |
31st Oct 2017, 11:30 pm | #416 |
Personally, I'm waiting for the oil turning.
---- Dave |
1st Nov 2017, 10:24 am | #417 |
Salt water can form a half-wave detector on sea-borne transmitters. Sometimes, in rough weather, a part of the broadcast programme could be heard, hideously distorted, presumably from resonant parts of the rigging.
3rd Nov 2017, 8:20 pm | #418 |
We could talk about PIM > BC appearing in Sea Borne RXs...
We could talk about the Hitch Hiker's theme - seem to think that is Bernie Leadon and a Banjo? Going by memory. We could talk about grammar. You can decline to give (verb) there is no way to do that with a gift (noun). All this is a long way from Audiophoolery. But it has parallels. This thread has become stale IMHO. Sorry |
3rd Nov 2017, 10:16 pm | #419 |
Indeed it has.
Everything that could be said, has been said in the thread, but then it had all been said some time ago. Perhaps the interest in the subject parallels how people in the past would go to bedlam to look at the inmates, to make themselves feel better.? David
4th Nov 2017, 1:07 am | #420 |
Re: The Audiophoolery Thread.
It's been on borrowed time for a while, some would say from the start, as we've had several threads on the same theme, largely covering the same ground. At least it didn't get round to biscuits!
