15th Nov 2017, 9:30 pm | #121 |
Re: Design-and-building a large valve Tesla coil (class C, Armstrong oscillator).
Hi Al, have a look at CVT's, capacitor voltage transformers
Used on power grids to read the line voltage at much lower cost than a wound one for 400Kv. Basically 2 HV caps and a transformer from the junction. It works on AC and can be pretty accurate (used for bulk metering) if the frequency is stable. Ed |
15th Nov 2017, 9:43 pm | #122 |
You got it! I applied a thin coat of varnish to stabilise the winding, then, after 24hours to let that dry, several thick coats, letting it dry for a day each time. After each coat I switched on the lathe, turning at about 15rpm for about 4 hours per coat to stop the varnish running. It worked much better than I hoped it would.
15th Nov 2017, 9:43 pm | #123 |
Hey Ed, will do, thank you. Are you thinking for me to apply this to measurements around my circuit? I'm building an EHT probe , but it's for RF signals, so it would still be useful for me to also be able to measure the pulsed DC in the power supply. Is that a suitable application for CVT's?
Al |
19th Nov 2017, 11:24 am | #124 | |
What’s your preferred varnish? Thanks again for your diligent and incredible work!
Al |
20th Nov 2017, 7:44 am | #125 |
I use whatever varnish i have lying around though the outside stuff seems to have a better finish.
Good to see your making progress Al. Andy.
3rd Jan 2018, 2:50 pm | #126 |
After all that work, the bottom line is, how long a spark will it generate?
"One small step for man".....because he has arthritis. www.retinascope.co.uk Albert. |
3rd Jan 2018, 9:07 pm | #127 |
View master, that’s the thing! We’ll never know. There is an approximate formula for valve Tesla coils, based on power in. According to that , we’d expect 70 cm plasma from the anti node, but the circuit was never realised with its new transformer. So it’s a moot point.
Somebody may care to take on the challenge: I will offer all the parts except the secondary coil for sale here before moving on to a EBay to recoup some of my spend.
Al |
