Old 12th Aug 2017, 5:00 pm   #1
FERNSEH
FERNSEH's Avatar
Default Gec 12" bt5144.
Electrically similar to the GEC BT2147 except for the 12" round triode CRT and having a box like wooden cabinet.
Here are the first pictures of the dismantled set.
Scary business removing the chassis from the cabinet as the CRT is not properly secured to the chassis, no metal band around the bowl of the tube, just a piece of co-ax cable. The mask is badly perished, it will be removed from the tube and turned 180 degrees so that the bad part is at the top and then the CRT and mask can be positioned safely on the lower metal supports. Also, must find a metal band for the CRT bowl
First job is repair that bashed chassis.
DFWB.
ID:	147754   Click image for larger version
FERNSEH is offline
Old 12th Aug 2017, 8:36 pm   #2
matspar
matspar's Avatar
Default Re: Gec 12" bt5144.
Looking good David! Very best of luck. Looks like we'll both be having similar issues with perished GEC shadow masks. That tube sits a lot further forward than on my 9" chassis.
matspar is offline
Old 12th Aug 2017, 9:40 pm   #3
MonochromeMarc
MonochromeMarc's Avatar
Hi David,
Well the chassis looks nice and grotty, should be fun !
What's the state of the cabinet ?
Marc.
MonochromeMarc is offline
Old 12th Aug 2017, 9:57 pm   #4
FERNSEH
FERNSEH's Avatar
Hi Matspar, The mask is pretty grotty and there's not much I can do with it although it's bit better now since I applied some linseed oil on it, the rubber has softened up somewhat.
Hi Marc,
The condition of the cabinet is not too bad, certainly there's no need to strip off the lacquer but that bashed up chassis is another matter....
DFWB.
FERNSEH is offline
Old 12th Aug 2017, 11:15 pm   #5
beery
beery's Avatar
Hi David,
I have a slightly better 12" GEC mask.
I might be able to pick it up in a couple of weeks if you are interested.
Andy
beery is offline
Old 13th Aug 2017, 1:12 pm   #6
FERNSEH
FERNSEH's Avatar
Hi Andy,
Thanks for the offer of the mask. Another picture of the damaged chassis. The right side panel should be an easy metal bashing job to straighten it out. However, I do have some problems with main chassis section, it's badly twisted.
DFWB.
FERNSEH is offline
Old 16th Aug 2017, 6:12 pm   #7
FERNSEH
FERNSEH's Avatar
Managed to straighten out the twisted chassis by using pieces of wood and the appropriate force necessary to get the job done.
DFWB.
FERNSEH is offline
Old 17th Aug 2017, 9:16 am   #8
Brigham
Difficult to see how the chassis could get so twisted.
Brigham is offline
Old 17th Aug 2017, 11:24 am   #9
PJL
I wonder how it got like that without smashing the cabinet or tube? A frustrated repairer?
PJL is offline
Old 17th Aug 2017, 1:33 pm   #10
FERNSEH
FERNSEH's Avatar
I was almost tempted to break up this set for it's parts. However, now that the chassis is straightened up I reckon it has the potential to be a decent set. The correct securing strap has been found for the CRT so that loop of co-ax cable can go. Even that perished mask can be tidied up. Just need to find the tensioning springs for the CRT strap.
It's amazing how the CRT has survived to whatever happened to damage the chassis. It took a fair amount of force to straightened it up.
DFWB.
FERNSEH is offline
Old 17th Aug 2017, 1:39 pm   #11
Tractionist
You do love a challenge! Rubber paint on the mask?
Red to red, black to black. Throw the switch and stand well back!
Tractionist is offline
Old 17th Aug 2017, 3:37 pm   #12
FERNSEH
FERNSEH's Avatar
"Rubber paint on the mask? "
It is a bit shabby to say the least. Looking at the chassis it would appear that it hasn't received much attention during its lifetime. Just a couple of RadioSpares capacitors and that's it.
DFWB.
FERNSEH is offline
Old 18th Aug 2017, 12:41 pm   #13
FERNSEH
FERNSEH's Avatar
And here is the reason why the CRT didn't implode when the set was damaged.
This is one robust tube. Evidence of that fact can clearly be seen around the periphery of the faceplate. The glass is very thick. Imagine if the CRT installed in this set was a Mazda CRM121? There would have been one almighty bang.
DFWB.
FERNSEH is offline
Old 18th Aug 2017, 3:06 pm   #14
Tractionist
As robust as that Advance signal generator? !!!
Keep going David - I love your 'sagas' .... truly!
Old 18th Aug 2017, 4:32 pm   #15
FERNSEH
FERNSEH's Avatar
That old Advance signal generator has been in service for more than forty years and is still spot on for calibration, it's good enough for aligning radios and most TVs.
Tried to attach the CRT to the mask, it's just not going to happen, so my next idea is to install the trimmed up mask in the cabinet and the chassis mounted CRT will then butt against the mask.
Attachment shows the mask test fitted in the cabinet.
DFWB.
FERNSEH is offline
Old 18th Aug 2017, 5:30 pm   #16
Heatercathodeshort
Heatercathodeshort's Avatar
Where do these orphan puppies from David? Woodworm, bent chassis, modified chassis, liquid masks and backless...
That BT5144 should be an easy one David. Don't turn it into a saga worthy of Metro Goldwyn Mayer complete with 1000 extras..
Regards, John.
Heatercathodeshort is offline
Old 18th Aug 2017, 6:02 pm   #17
FERNSEH
FERNSEH's Avatar
HKS wrote: "Don't turn it into a saga worthy of Metro Goldwyn Mayer complete with 1000 extras.."
Hi John,
Would I do that?
DFWB.
FERNSEH is offline
Old 18th Aug 2017, 7:51 pm   #18
FERNSEH
FERNSEH's Avatar
Four wood strips locate the safety glass and mask into position. Metal or wood clamps will be made to secure the assembly in situ.
DFWB.
FERNSEH is offline
Old 29th Aug 2017, 4:55 pm   #19
FERNSEH
FERNSEH's Avatar
At last a start on the electrical restoration of the GEC BT5144. Initial tests on various capacitors revealed that the 4 + 8mfd sound HT supply decoupling can electrolytic was useless, so was the 50mfd cathode bypass capacitor of the N37 frame output valve. A few waxies have been replaced, in fact these were service replacements which might have been fitted in the 1950s.
The main HT capacitor might well be OK, it holds it's charge after been given a taste of electricity. Lots of problems with the heater chain, bad contacts on many valveholders and wires had came adrift on the RF deck octal plug. All sorted now and the variac is presently supplying the set with reduced mains power.
AC is present at the anode of the metal rectifier but there is absolutely no DC at the cathode, it's totally useless. The replacement will have to be a silicon diode and series resistor. Let's try that and find what happens when the HT supply is re-established.
DFWB.
FERNSEH is offline
Old 29th Aug 2017, 5:14 pm   #20
FERNSEH
FERNSEH's Avatar
In fact the failed ST&C type RM4 metal rectifier is a service replacement and is slightly shorter than the original GEC component.
DFWB.
FERNSEH is offline
