21st Mar 2024, 4:15 pm | #1 |
Century Super. Help Needed.
I have an early 1930s 2V five valve radio that I am in the process of trying to renovate, it featured in Amatuer Wireless and was called the Century Super
the major problem is I just cant the thing working, I have done all the obvious checks, replaced components where necessary but it is still dead as a doornail so I have reached my level of incompetence and was looking for somebody that could spare an hour or two and look at it with me - I am more than happy to bring it over to whoever, I can bring the appropriate power supplies etc. Is there a member in the Watford, St Albans, Radlett area that knows what they are doing unlike me! there is no hurry and I am happy to work round any time that is suitable some advise would be most helpful! i have attached some photos and the circuit regards Dick |
21st Mar 2024, 4:25 pm | #2 |
Re: Help Needed
Hi Dick No pictures currently loaded.
If your having trouble there is a guide here. https://www.vintage-radio.net/forum/...ad.php?t=77650 Cheers Mike T
21st Mar 2024, 5:21 pm | #3 |
Re: Century Super. Help Needed.
Hi Mike
i am having trouble attaching images - can i edit my existing thread to do this? regards Dick |
21st Mar 2024, 5:24 pm | #4 |
Sorry, but no. Just attach your pictures to a new post in the current thread.
22nd Mar 2024, 12:31 am | #5 |
Have you checked the continuity of the windings in the interstage transformers (if fitted)?
22nd Mar 2024, 9:44 am | #6 |
Hi Silicon
thanks for coming back to me not sure which bits you are referring to, i can for some reason post any pictures or circuit i could e mail them to you - my e mail is REMOVED BY MODERATOR regards Dick |
22nd Mar 2024, 10:02 am | #7 |
Please be more specific as to why you cannot upload pictures. Are you getting an error message for example?
22nd Mar 2024, 10:56 am | #8 |
hi
yes error message says i dont have permission to access the page |
22nd Mar 2024, 11:05 am | #9 |
The procedure for uploading pictures can be found here:-
https://www.vintage-radio.net/forum/...ad.php?t=77650 At what stage do you get the permission denied message?
22nd Mar 2024, 11:23 am | #10 |
when i hit upload
22nd Mar 2024, 12:18 pm | #11 |
Whilst the pictures get sorted.
https://www.worldradiohistory.com/UK...1-05-S-OCR.pdf starting page 710. Its an early superhet so the first questions I would have: Is the local oscillator running? this set is shown as having six valves rather than five so is this the correct set? Cheers Mike T
22nd Mar 2024, 12:51 pm | #12 |
Richard55.
Email the pictures to me and I'll upload them for you. I'll PM you my email address shortly.
22nd Mar 2024, 1:42 pm | #13 |
Here's the pictures.
Richard has confirmed that this is a 6 valve set.
23rd Mar 2024, 8:35 pm | #14 |
For information.....
25th Mar 2024, 11:32 am | #15 |
Hi All
given that so far there is nobody available to show me a solution in person can anybody give some advise on next steps i would like to check that the HT voltages are correct at the right points wheer should i check and what voltages should i expect if i can get this right then hopefully we can move on to stage 2! regards Dick |
25th Mar 2024, 12:03 pm | #16 |
Hi Dick assuming that you have all correct LT and HT voltages to the set I would start by checking for voltage on the anodes of all the valves , also you should have ht on the screen of the two sg valves, let us know your results, have you checked the valves heaters for continuity. What are you using for a speaker. Mick.
25th Mar 2024, 12:09 pm | #17 |
This is a battery set. The various HT voltages aren't shown on the diagram, but I assume they're stated in the text?
What power supply arrangements are you using? Something like PP3's in series? Personally I'd start by checking that all the valves light up, assuming you can see the filaments, this set uses directly heated valves with no separate cathodes. The first place to check the HT voltages is at the batteries themselves, then you can proceed to test at the point where the battery leads connect to the set. Note that there's a fuse in the HT negative line, have you tested that for continuity? Assuming the HT is reaching the set, the next place to measure the voltages is within the set. It isn't that difficult to follow the circuit diagram. For example HT+1 should be present at the anode of the first detector valve. You can measure HT voltages initially without the need to have the LT supply connected.
25th Mar 2024, 1:24 pm | #18 |
thanks Graham and Mick
i am using an Amplion power supply and have checked that correct voltages are present at the terminals on the back of the radio all valves have continuity and i have checked for 2V at each valve socket (F to F) i am using SG Brown headphones i will check the HT voltages as suggested and report back once again thanks for the help |
25th Mar 2024, 1:33 pm | #19 |
High Impedance headphones I hope? This set has no output transformer.
Also check that grid bias is present on the grids of the Oscillator and Output Valves.
1st Apr 2024, 4:02 pm | #20 |
Gentlemen
here are the results of my voltage checks Oscillator Anode = 7.8V 1st Det Anode = 42.4V 1st SG - at the Anode 12.7V, at the SG terminal = 9.2V 2nd SG - at the Anode 12.8V, at the SG terminal = 9.2V 2nd Det - at the Anode 196.6V Power Valve - at the Anode 0V i presume i should be worried about the 2nd Det and Power Output? regards Dick |
