Forum Announcements and Comments Announcements about forum changes will be made in this section. All new threads here now require moderator approval. |
22nd Sep 2023, 11:13 am | #1 |
Anyone else having forum problems?
Anyone else having problems today uploading photos on here and long delays generally?
22nd Sep 2023, 11:18 am | #2 |
Re: Anyone else having forum problems?
The forum has been behaving completely normally for me this morning.
22nd Sep 2023, 11:30 am | #3 |
What error messages or W.H.Y did the OP receive?
22nd Sep 2023, 12:11 pm | #4 |
No messages . Just did not happen . Must be my iPad .
23rd Sep 2023, 9:14 am | #5 |
Just a thought, my sons iPad and iPhone did long winded updates yesterday (friday) which, for the duration, slowed things down a lot for him. Maybe yours was updating?
Dave G1AGK. My perception is my reality! |
23rd Sep 2023, 10:18 am | #6 |
All seems OK for me yesterday and today.
David |
26th Oct 2023, 6:02 pm | #7 |
I'm getting persistent problems with the same posts in a thread repeating over and over again even on "page 2" and "page 3" whenever I select the next page along from the buttons at the bottom, a recent example being the "ICC8 Frame fault".
Chris Williams
It's an enigma, that's what it is! This thing's not fixed because it doesn't want to be fixed! Last edited by Chris55000; 26th Oct 2023 at 6:10 pm. |
30th Oct 2023, 11:41 am | #9 |
For a few weeks now I'm getting an old problem which is when clicking on thumbnails for photos, only the first one opens, clicking 'next' is ignored and I can only view it by right-clicking and 'open link in new tab'. Even then, sometimes I only get half a picture with the other half just white.
It happened a few years ago too but went away.
Kevin |
6th Nov 2023, 3:29 pm | #10 |
I've just had the problem uploading images; the 'manage' window gave a message in red about not uploading and "the management team have been informed"
I posted my reply without images, but the text 3? came out as 3?
- Julian It's good here |
6th Nov 2023, 3:31 pm | #11 |
There you go - 3 (capital Omega) -> 3?
6th Nov 2023, 3:48 pm | #12 |
Administrator
I had a database error email about that one. Problem is the ohm symbol isn't valid for the current database collation, hence the question mark. At some point I will change all database tables to UTF-8 but it needs testing first and the forum will need to be closed while it is done.
6th Nov 2023, 3:51 pm | #13 |
Thanks, I'll rename my images and try again - but have you any news on posting an ohms symbol?
6th Nov 2023, 3:55 pm | #14 |
Administrator
Until I change the database collation to UTF-8 it's not possible. I'll probably look at it over the Christmas break but no promises.
6th Nov 2023, 4:04 pm | #15 |
As a general rule, it's advisable to post using the standard ASCII character set rather than trying to use Unicode stuff or emojis. It can produce all sorts of strange database errors without necessarily giving any meaningful feedback to the poster.
6th Nov 2023, 6:45 pm | #16 |
Here's an Ohm sign - I copied it from this post last year
? and here's one I copied from a textfile ? (edit) didn't work but I can live with that
6th Nov 2023, 6:53 pm | #17 |
So how come there was an ohm symbol possibility that worked
back in 2002? Mike |
6th Nov 2023, 7:12 pm | #18 |
The database software has changed in that time. As Paul suggests, it can be reconfigured to reduce the issues, but there's a fair bit of work involved.
6th Nov 2023, 8:02 pm | #19 |
Administrator
Yes, the forum has moved to different hosting a few times since 2002, and hosting software including databases has changed considerably over that time. There was a MySQL database server update from 5.7 to 8.0 recently (because 5.7 was end-of-life) which has caused some of these character set issues.
I set the forum software to use UTF-8 after that update to make it mostly work, but the database tables are all still standard ASCII. I need to change all the database tables to UTF-8 too, which should hopefully solve these niggles, but it is a big job and needs testing thoroughly first as it could break other things. I intend to look into this over the Christmas break. The version of vBulletin we are using (3.8.11) doesn't officially support MySQL above 5.7. It is out of support and hasn't had any updates since 2017. So changes and fixes to keep it working as the server software is updated are up to me to sort. Updating to the current version of vBulletin would cost $180 initially then $80 per year for updates, so that's not happening. We will keep going with what we have for as long as possible. Eventually I will need to look into moving to something like phpBB, Simple Machines or MyBB which are all open source. However none of them have fully working converters so migrating will be a massive job (the decision of one which to use would probably be which is the least difficult to migrate to). |
7th Nov 2023, 8:58 am | #20 |
Are their other issues besides the ohm symbol, seems a lot of work and uncertainty just to fix that item?
Frank |
