4th Dec 2016, 7:05 pm | #41 |
Re: Tandberg 64x after changing capacitors
Hi Graham, i have measured it against the chassis...i will measure again against the negative rod of one of the caps...will updated in a bit..
4th Dec 2016, 7:40 pm | #42 |
New measures against the neg rod of one of the cap:
ECC81s 1: 87V 1: 136V 2: 0V 2: 0V 3: 2V 3: 0V 4: 12V 4: 12V 5: 25V 5: 25V 6: 72V 6: 69 V 7: 0V 7: 0V 8: 6V 8: 0V 9: 19V 9: 19V ECC 82s 1: 42V 1: 0V 2: 0V 2: 0V 3: 1V 3: 1V 4: 13V 4: 0V 5: 25V 5: 26V 6: 192V 6: 197V 7: 6V 7: 6V 8: 31V 8: 30V 9: 20V 9: 19V ECC83s 1: 130V 1: 122V 1: 123V 1: 3V (anodes) 2: 0V 2: 0V 2: 0V 2: 0V (grids) 3: 1V 3: 1V 3: 1V 3: 0V (cathodes) 4: 0V 4: 0V 4: 0V 4: 0V (heaters) 5: 12V 5: 12V 5: 13V 5: 13V (heaters) 6: 136V 6:126V 6: 91V 6: 3V (anodes) 7: 0V 7:0V 7: 0V 7: 3V (grids) 8: 1V 8:1V 8: 0V 8: 2V (cathodes) 9: 6V 9:6V 9: 0V 9: 7V (heater centre taps) I have double checked the numbers of the pins to the printed out PCB schematic board.. |
4th Dec 2016, 7:52 pm | #43 |
It might help if you post the voltages with respect to the valve's circuit designation, Eg:
V1, V2, V3 etc. Lawrence. |
4th Dec 2016, 8:31 pm | #44 |
I have posted the measurements of where and which tubes on the PCB board.....still feeling like
4th Dec 2016, 9:05 pm | #45 |
Voltages aside, for anyone following this, the circuit designations for the valves on the playback amplifier board (1st thumbnail) are:
Top left = V6 (ECC83) Top right = V5 (ECC83) Bottom left = V8 (ECC82) Bottom right = V7 (ECC82) Circuit designations for the valves in the 2nd thumbnail are already given on the board. Lawrence. |
4th Dec 2016, 9:16 pm | #46 |
Thanks Lawrence
This is my first time dealing with such a machine..absolute beginner on tube gears.. are the readings suggests a resistor issue? |
4th Dec 2016, 9:22 pm | #47 |
Not sure, not looked at the voltages yet but will do.
Lawrence. |
4th Dec 2016, 9:58 pm | #48 | |
I've added some electrode designations to post #42.
Let's concentrate on the ECC83's. One of these has very low anode voltages on pins 1 and pin 6. Locate the resistors connected to these pins. With power OFF measure these resistors using your meter on a suitable ohms range. (One meter lead to each end of the resistor). Compare this with the specified value. The valves can be in or out. If the values are OK, apply power with the valves in and measure the voltage on BOTH ends of these resistors with respect to the capacitor you were using in post #42. Post the results here. Quote:
4th Dec 2016, 10:17 pm | #49 |
Ok...One board at a time, playback amplifier board (1st thumbnail in post#44)
The valve heater voltages don't make sense in the thumbnail, it's a series parallel arrangement for the heaters, V7 & V5 heaters are connected in series, V8 & V6 are also connected in series, those two series circuits are connected in parallel across the 25 volt DC heater supply. Looking at the V7 & V5 series string, the heater supply voltage (25v +ve) comes in from point 26 on the board and goes to heater pin 5 of V7 where you've recorded a voltage of 26 volts (that's close enough) On heater pin 4 of V7 you've recorded a voltage of 0v, however, that heater pin is connected to heater pin 5 of V5 on which you have recorded a voltage of 13 volts, there's a discrepancy there. To complete that series circuit, heater pin 4 of V5 connects to point 27 on the board (chassis/ground) Looking at the V8 & V6 heater series string the voltages are more or less in the ball park, so should be no problem there. So....Do all the valve heaters on that board glow when power is applied? There are other voltages that are badly out on that board but first things first...Heaters. This post might cross. EDIT: Post crossed with Graham's. Lawrence. Last edited by ms660; 4th Dec 2016 at 10:32 pm. Reason: grammer |
4th Dec 2016, 10:23 pm | #50 |
Lawrence.
We been here before as far as heater voltages are concerned. Further up the thread in post #35, I had the OP check the voltages between pins 4 and 5 of every valve and he got around 12V. Perhaps there's an intermittent fault, but we're going round in circles.
4th Dec 2016, 10:29 pm | #51 |
Low anode voltage is inconsistent with no heater voltage.
4th Dec 2016, 10:34 pm | #52 |
Are the heaters on this machine AC? If you measure with DC then you get zero.
4th Dec 2016, 10:35 pm | #53 |
The heaters are fed from a 25V DC supply and are connected in series parallel combinations.
4th Dec 2016, 10:43 pm | #54 | |
Lawrence. |
5th Dec 2016, 7:49 am | #55 |
Thanks for all your help guys... before I start and measure the resistors... could these symptoms be caused by a faulty ECC83? or definitely resistor...
5th Dec 2016, 9:50 am | #56 |
Valve = less likely, resistor/capacitor/or a PCB short = more likely, carry out Graham's resistor test.
Lawrence. |
5th Dec 2016, 6:56 pm | #57 |
Hi Graham,
Thank you for this. I have measured two resistors next the ecc83 which had no power nearly. Power off: R214 0,1 MOhm with power off measures 0.1018 mOhm / Power on: Can't measure anything. My meter wont respond at all. Measuring against the neg rod of a cap. R208 47kOhm wit power off measures 44.7kOhm Power on: can not measure anything, no response of my voltmeter. |
5th Dec 2016, 7:20 pm | #58 |
You probably have a disconnection in the PCB track leading from the resistors to the power supply rail.
5th Dec 2016, 7:37 pm | #59 |
I have checked the pcb and it seems okay..no loose pins or components. I have used a magnifier glass too to go through but i will double check it maybe I have missed something...any other components could be faulty? any other resistors? Thank you Graham....
5th Dec 2016, 7:42 pm | #60 |
Also R224/C214 ? Voltage check both ends of R224 with respect to ground (HT -ve)
Lawrence. Last edited by ms660; 5th Dec 2016 at 7:51 pm. Reason: alteration |
