Old 20th Nov 2012, 5:52 pm   #81
mhennessy
Default Re: Calling Hacker Hunter owners!
Yes, I felt sure you'd know
I've seen plenty of Hunters with damaged audio PCBs, but these can normally be cleaned up. Your first problem might be undoing the screws. Often, I end up replacing the original screws with M4 countersunk screws of the same length (an M4 thread can be cut in the heatsink without drilling out the holes). I often find that the solder has gone strange - all grey and crystalline, perhaps because of the chemicals - so start by removing all the old solder and applying fresh. Any corroded copper can be cleaned up and patched with tinned copper wire, but as these had a solder-resist layer, they normally get away with it. Component damage is common - the pre-set resistors can be damaged, and I routinely check the values of the fixed resistors. T1 can go noisy, and I use the more reliable BC108 to replace the BC148. The germanium transistors can go leaky, low gain, or develop tin whiskers. Apart from that, it's all pretty reliable - even the capacitors are normally pretty good.
Again, I might well be teaching you to suck eggs again, but it might help others. Good luck with the restoration - take some "before" pictures, and I expect to see the "success story" in a few days time
Cheers,
Mark
mhennessy is offline
Old 20th Nov 2012, 9:34 pm   #82
Nickthedentist
Nickthedentist's Avatar
Thanks for the advice and encouragement!
I should be so lucky... work's hectic, there are two little ones to look after, and I've got to mend the boiler which has just broken down. Brrrrrr
Nickthedentist is offline
Old 25th Nov 2012, 4:00 pm   #83
magicman
Just joined so first post.
Picked up my Hunter about ten years ago at a boot sale for £7.50, it's in very good condition and works as it should it's stats. are as follows.
Mod. RP38 Hunter VHF
Ser. No. 10310
Handle One piece
Grille Sheet Ali.
Scale All white
DC in No
Spkr. Elac grey frame
Tone knob Silver
There is a label inside with the following written on it in biro MO 833 followed by a signature.
All the best,
George
magicman is offline
Old 26th Nov 2012, 9:55 pm   #84
mhennessy
Hi George,
Thanks for the information, and welcome to the forum
Your set is the earliest we have with an Elac loudspeaker - this gets us closer to 10,000, which is when I suspect they made that change...
The only thing I need to know about your set; is it black or teak?
Thanks once again,
Mark
Old 27th Nov 2012, 12:58 pm   #85
magicman
Hi Mark,
The wooden ends are teak and the rexine appears to be navy blue.
This is a brilliant site by the way, glad I stumbled upon it. I've had dozens of portable radios in my time but nothing beats the Hacker Hunter.
George
magicman is offline
Old 28th Nov 2012, 1:09 am   #86
mhennessy
Thanks George!
I'm guessing that your Hunter left the factor with black Rexine, but has faded slightly. Certainly, black was the only colour used for a Hunter. There is a chance that it's been recovered, but this is relatively unlikely.
Glad you're enjoying it, and thanks again for the details.
Mark
Old 30th Dec 2012, 5:27 pm   #87
credible58
Hi Mark,
The work you have done on the timeline is excellent. I've tried to use it to see if I could narrow the date of manufacture of my RP38A (serial 13924). The evidence is mixed.
1. R3 and R5 in my set are the values that were used after 7th October 1970
2. There is a red stamp on the inside of the case near the speaker hole that says 10 SEP - unfortunately no year
3. The timeline has serial number 14291 produced on 21/10/1970
Taking points 1 and 3 above, the difference in serial numbers is 357. If mine was manufactured on 7th October then that would give a manufacturing rate of 175 to 200 units per week. That sounds quite high.
* What's wrong with my logic above?
* Is there anything else I could check?
Thanks and regards...Paul
credible58 is offline
Old 5th Feb 2013, 8:43 am   #88
Dmartinburns
HI there
This is my first post as a newbie and I wanted to register my Hacker Hunter RP38a. Unfortunately I cannot seem to locate the serial number. The only number I can find is '45547' on a sticker affixed to the underside of the bottom panel, but I do not think this is the serial number. My Hunter has the one piece handle, sheet aluminium type grille, black 'Hacker' badge to the upper left on black leatherette, wooden end panels, white scale print with 'Hunter VHF' to the top left, fitted dc input socket (but sadly no power supply lead), silver tone controls and a 'gold' speaker.
I paid £50 odd for it just after Christmas, and am suitably impressed by the build quality and sound.
Assuming the number above is not the serial number, where is this usually found?
Best regards
Martin
Dmartinburns is offline
Old 5th Feb 2013, 5:50 pm   #89
Darren-UK
Hi Martin,
45547 is the serial number. It should also be stamped onto the underside of the alloy chassis immediately below the tuning scale; remove the back, hold the radio face down and you'll see it at the righthand end.
Darren-UK is offline
Old 5th Feb 2013, 5:58 pm   #90
Dmartinburns
Thanks Darren, and of course you are correct as the chassis serial number confirms. Can this set be registered now on your database please?
Old 5th Feb 2013, 7:06 pm   #91
mhennessy
Hi Martin,
Many thanks for the details of your set, which is the latest example of the sheet aluminium grille that I know about. Every other detail is as expected, which is always nice. I've added the details to the timeline document (next time I get around to uploading it, you'll see it). I'll also add the details to the database on the Hacker Radio Yahoo group.
All the best,
Mark
Edit: I presume the "Hacker" badge is the pressed aluminium version, rather than chromed brass?
Old 6th Feb 2013, 4:48 pm   #92
Dmartinburns
Yes, the badge is pressed aluminium.
Old 7th Feb 2013, 3:21 pm   #93
FERNSEH
FERNSEH's Avatar
Just saved another Hacker Hunter radio. This one appears to be of late 1960s manufacture. The serial number is 10286, has a grey Elac loudspeaker, single tone control. No power socket on this set.
The set didn't need much work, the pressed aluminium speaker grill had some dents which have been sorted out.
No electrical work required whatsoever, the set worked immediately on applying 18 volts from the bench power supply.
First class sound quality on FM, lively on MW but not so good on LW, doesn't receive RTE1.
DFWB.
ID:	75903   Click image for larger version
ID:	75904   Click image for larger version
ID:	75905   Click image for larger version
ID:	75906   Click image for larger version
FERNSEH is offline
Old 7th Feb 2013, 11:05 pm   #94
mhennessy
Hi FERNSEH,
Many thanks for those details - yours is the earliest I have on record with the Elac loudspeaker. Excellent restoration, especially that front grille! The weak LW might be fixable; it might be as simple as doing an RF lineup.
All the best,
Mark
Old 8th Feb 2013, 12:53 am   #95
FERNSEH
FERNSEH's Avatar
Hi Mark,
The set appears to of late '60s production, the electrolytic capacitor in the attached picture is dated 6742, 42nd week of 1967.
Transistor TR1 is a Mullard BF194 and has the code D39 on it. Tr3 is a Mullard BF194b and has the code 0g3. I'm not sure if these codes are the date manufacture or for other purposes.
DFWB.
FERNSEH is offline
Old 10th Feb 2013, 1:48 pm   #96
westcliff
westcliff's Avatar
Hi Mark,
I've got myself another Hunter, so hear are the details for your records:
Model - Hunter VHF RP38A.
Dial - White and green printing.
Speaker - Frame is unpainted, gold-coloured metal. "Elac" sticker on side. Stamped ""38HE/146 15 (ohm sign)". I think it's "38"; it's a bit smudged.
Grille - Mesh.
Badge - Metal "Hacker" badge on black vinyl at top left of front. This badge is different from those on my later RP38As in that it does not have a box surrounding the letters, which are raised and chrome-coloured on a black background.
Handle - One-piece.
Serial number - 23876 stamped on chassis; 28693 on white paper sticker on bottom of case. Oh dear.
I hope this information is helpful.
Gus.
westcliff is offline
Old 18th Feb 2013, 12:50 am   #97
mhennessy
Hi Gus,
Sorry it's taken a while to respond to this
Fascinating!
Looking at my data, nothing appears to have changed between the two numbers you have, so fortunately that doesn't muddy the waters in any way. Whoever made up the set obviously did it from two identical examples - which is good going when you consider how many changes this set saw over the years!
All details check out with just one exception; the unpainted loudspeaker didn't put in an appearance until ~33,000. This suggests that this set is actually the product of at least 3 different Hunters.
The lettering on the 'speaker is almost certainly "58HE/146". The first two numbers indicate the size (5" by 8")
The earlier style badge you have (chromed brass rather than the later pressed aluminium) is correct for this model version.
Presumably the handle doesn't have a Rexine insert?
For my records, I think I'll take the chassis number. After all, the paper sticker might well fall off.
Thanks - and sorry again for the delay in replying...
Mark
Edit: I presume it has teak sides?
Old 27th Feb 2013, 9:26 pm   #98
juliosham
Hi Mark,
I'd like to register my Hunter please.
Details as follows;
Designation - RP38A Hunter VHF
Serial Number – 13347
Handle Type – Single Piece
Grille type – Grille type sheet Aluminium
Scale print – White with green lettering on MW
DC Input socket – No
Speaker – Elac with grey finish (58HE/146 printed on speaker)
Wave-Change Buttons - Black with Silver Insert
Tone control – Silver
The radio is covered in Black Rexine
This is my first Hacker which I bought last year. I had previously been collecting Roberts sets and a small valve set (Bush VHF70). The Hunter is my favourite of my transistors though. Sounds fantastic.
Thanks,
Brian
juliosham is offline
Old 27th Feb 2013, 11:23 pm   #99
mhennessy
Hi Brian,
Many thanks for these details - I've added the set to my timeline document, so you'll see it when I get around to uploading the next version. I'll add it to the Hacker Radio Yahoo database in a moment.
Yours is the earliest RP38A I know about - previously it was 13670 (one of mine), so we've narrowed down that change by 323. Excellent!
Glad you're enjoying the set. Only one though
All the best,
Mark
Old 3rd Mar 2013, 1:58 am   #100
Hybrid tellies
Hybrid tellies's Avatar
Hi I have just dug mine out. Looking at the other entries mine does not look anything special but one more to add to your resgistry
Model Designation: RP38A, HUNTER VHF
Serial number:36119
Handle Type: Single Aluminium
Grille Type: Flat Mesh
Scale: All UK stations in white, all European and Irish stations in green
DC input socket: Yes
Loudspeaker: Gold finish ELAC with label still attached
Tone controls: Silver (bass and treble)
On/Off Volume and Tuning control:Silver
Cabinet: Black resine with wooden teak ends.
I bought this a few years ago at the NCVF. Sadly it has been got at by the phantom dabbler with all IF coils twiddled. That is why it has been sitting on my long to do pile for the last few years. Its a pity because it does look in good condition with only a few dents on the speaker grille and no signs of battery corrosion on the inside.
Name:	Hacker RP38A 3.jpg
ID:	76989   Click image for larger version
Name:	Hacker RP38A 3 (1).jpg
ID:	76990   Click image for larger version
Name:	Hacker RP38A 3 (2).jpg
Simon
BVWS member
Hybrid tellies is offline
