Old 30th May 2017, 12:33 am   #1
petertheorgan
petertheorgan's Avatar
Default Radar Cathode Ray Tube Reactivator Type 202.
I have been given a Radar type 202 CRT tester and reactivator. It produces the heater volts as requested, but I am unable to get any readings for emission. It appears to have HT, LT and the meter is working on other ranges, but I cannot produce any measurable beam current.
I have the instruction sheet but I just wondered if anybody had a circuit or knew where I could obtain one.
Thanks again in advance,
Peter
petertheorgan is offline
Old 30th May 2017, 7:23 am   #2
thermionic
thermionic's Avatar
Default Re: radar cathode ray tube reactivator type 202
Hi Peter.
I have one of these too, but alas, I have no circuit either to help you!
Problems I have had on mine were with dry joints & oxidisation on the wafer switch contacts. The Clear Short push switch became intermittent, disconnecting the meter movement, and a couple of the 20 percent carbon comp resistors had far exceeded their intended tolerance!
I hope you get to the bottom of this - I've found mine to be very useful.
I'm away from home at the moment, but I'm happy to take voltage readings for comparison with mine if that helps.
SimonT.
The honesty of imperfection..........
thermionic is offline
Old 30th May 2017, 8:06 am   #3
Restoration73
Restoration73's Avatar
I also have one of these but have not yet traced the circuit. However that in post #6 is
very similar:
https://www.vintage-radio.net/forum/...ad.php?t=65435
Restoration73 is offline
Old 30th May 2017, 6:32 pm   #4
Freya
Freya's Avatar
Default Re: Radar Cathode Ray Tube Reactivator Type 202.
One of the best around in my opinion, you need to have the lead connected to pin 6 on the octal plug (also A3) and the final anode to get the beam current emission displayed.
Stephen
Freya is offline
