28th May 2017, 6:54 am | #1 |
Restoring a Murphy Baffle A104
Hello,
In June I will start restoring my Dad's Murphy Baffle A104. It saw many years use in our outbuilding and sadly I eventually neglected it, simply through lack of use. It no longer shows any activity when turned on, so I suspect there are several things wrong which will need to be tracked down. I have moved the set into the dry for the last 6 months and I will take the back panel off and have a quick look. I did find the circuit schematic on the web so I have something to go on at least. The outside of the set has suffered a bit, and might need replacement veneer (if that's even possible). Certainly all the metalwork will need to be restored. At least one control knob is broken, so if anyone has any sources(!)? Anyway, that's my next project. I remember my Dad absolutely loved the sound of the Baffle, it would be great to bring it back as a nice reminder! Last edited by AC/HL; 28th May 2017 at 12:55 pm. Reason: Forum rule B8 |
28th May 2017, 8:43 am | #2 |
Re: Restoring a Murphy Baffle A104
You will find it quite challenging, but could I gently point out that you have started badly?
Never just turn on an old radio of unknown condition without some preliminary exploration. You risk ruining the transformers and output valve/s, expensive and difficult components to source replace. Sam. |
28th May 2017, 10:27 am | #3 |
Before concentrating on the less relevant cosmetics ("restoring" metalwork makes no difference to the electronic performance) you need to get the set working. Do you have the relevant skills to safely do this?
Edward. |
28th May 2017, 11:47 pm | #4 |
Hi folks,
Points taken! The radio is not totally unknown, we have had it in the family for years and eventually it stopped working. Once I discovered it was not functioning I left it alone until now. I won't be powering it up without more examination. I have experience with electronics (I work in the field) so while I am not greatly experienced with valve radio repair I have useful skills and an understanding of the risk involved. I'm aware I'm working with high DC voltages and stuff that is way past its prime. Of course, I'm open to any helpful advice! |
1st Jun 2017, 11:48 am | #5 | |
It's a shame I recent passed on my second A104 (I see no point having two) it might have been helpful for you.
Clive |
