Old 26th May 2017, 11:52 pm   #1
Chris55000
Default "Wheatstone Bridge" Hum Cancellation!
Hi!
I think this technique originiated from Australia as an alternative method of residul-hum cancellation in inexpensive receivers to avoid the use of expensive chokes, high-wattage-resistors, and the need to have the h.t. output from the rectifier no more than the absolute minimum needed for the output valve!
It's based on "Wheatstone Bridge" techniques, and has the advantage of not needing an O/P transformer with a tap on it!
Altho' shown for an a.c. only receiver, it can be used for an a.c./d.c. type power pack, but care needs to be taken not to accidentally interpose the heater-chain current in the -h.t. lead bias resistor - this is ensured by lifting the bottom-end of the heater-chain from chassis, directly returning it to mains N via the on/off switch neutral-pole, then connecting the bias resistor from there to chassis.
I attach the paper the idea came from!
Chris Williams
Chris55000 is online now
