24th May 2017, 6:13 pm | #1 |
Tuning range of this beauty?
This is a pull from probably a Racal board.
I would like to use it to fine tune my magnetic loop antenna (in parallel with a small hand-wound inductor) It appears to have a fine brass mechanism to vary inductance, but by how much? I'm guessing a fraction of a uH?? I have several, they're not easy to extract from a double sided board with integral ground-plane!! Thanks folks
Al Last edited by Al (astral highway); 24th May 2017 at 6:14 pm. Reason: Forgot photo |
24th May 2017, 6:38 pm | #2 |
Re: Tuning range of this beauty?
Are you sure this is not a trimmer capacitor? A small variable inductor will have a coil
construction - small values have a plastic former with an aluminium slug. |
24th May 2017, 7:03 pm | #3 |
It's so tiny that it could be either. If it's an inductor, it has stray capacitance. If it's a capacitor, it has stray inductance!
Al |
24th May 2017, 7:11 pm | #4 |
Of course. Every component has resistance, capacitance and inductance. Actually I can believe in zero resistance (superconductivity), but not zero capacitance or inductance (which would require major changes to electrodynamics).
But what is the DC resistance between the connections of this component? A trimmer capacitor would be open-circuit, a (small) inductor essentially short-circuit. |
24th May 2017, 10:23 pm | #6 |
Cheers, Jim! I love that company! Been a while since I ordered from them but they always have things that are unobtainium in th UK!
Al |
