Old 16th May 2017, 4:53 pm   #21
Station X
Station X's Avatar
Default Re: GPO Telephone 741 conversion.
I'm just imagining what my supervising technician would have said to me if I'd done a job like that nearly 50 years ago.
Graham. Forum Moderator
Station X is online now
Old 16th May 2017, 4:55 pm   #22
Station X
Station X's Avatar
Originally Posted by davidm123 View Post
OK I'll do that, see you in a min but why now has it stoped ringing?
Perhaps there's no internal capacitor in your master jack? Sounds unlikely though.
Old 16th May 2017, 4:58 pm   #23
davidm123
I took the red bit off like you said and now I get a dialing tone and I can dial out I still can't get the phone to ring.
davidm123 is offline
Old 16th May 2017, 5:02 pm   #24
Station X
Station X's Avatar
Put the T6-T7 strap back. If that cures the problem you have a problem with your master jack or extension wiring.
Are you using the master jack or an extension jack?
Old 16th May 2017, 5:04 pm   #25
davidm123
extension as my master socket
Old 16th May 2017, 5:08 pm   #26
Station X
Station X's Avatar
Is it my imagination, but was the strap from T6 to T7 trapping the blue wire running from the bell to T16?
Old 16th May 2017, 5:10 pm   #27
Station X
Station X's Avatar
Sorry, but I don't understand you answer. Is your telephone 741 plugged into the master jack on an extension jack?
A master jack will have a circuit board with components on it. An extenson jack is just a jack.
Old 16th May 2017, 7:09 pm   #28
davidm123
sorry for long delay in replying but the phone fully works now thank you so much for your help i am so happy with it thank you all again
Old 16th May 2017, 7:28 pm   #29
ThePillenwerfer
ThePillenwerfer's Avatar
Is this with or without the T6-T7 strap?
This connects a capacitor which is needed to make the bell ring. You shouldn't really need it as these days this is in the Master socket; that being the one the cable from the outside world goes to. Other sockets are Secondaries and don't have one.
The Master Socket is connected to the Secondaries by three wires. If one of these, the one that goes to terminal 3 in the socket, is broken a telephone plugged into that Secondary will work but it's bell won't ring.
Whatever the situation with your installation the main thing is that you've got it working to your satisfaction.
ThePillenwerfer is offline
Old 16th May 2017, 7:50 pm   #30
davidm123
that is with the T6-T7 Strap in place
Old 16th May 2017, 9:09 pm   #31
Dave Moll
Dave Moll's Avatar
I'm glad to know you now have it working. As you have the internal capacitor in circuit (T6-T7 and T8-T9 straps in place) it would be good practice to move the blue wire to a spare terminal (say T14, the one to the left of the green wire) so that connecting the 'phone to a master socket wouldn't place this capacitor in parallel with that in the socket.
One thing you may need to be aware of with this arangement is that a second loop-disconnect (pulse) dialling 'phone would cause "bell-tinkle" on this 'phone when it dials - and maybe also vice versa. This is not a problem other than potentially being an irritation.
Dave Moll is online now
