Old 16th May 2017, 3:19 pm   #21
PJL
Default Re: Candlestick Telephone help.
Originally Posted by sitwell View Post
thanks pjl is any chance of a pic of the leaves side on
The link in post #13
PJL is offline
Old 16th May 2017, 3:47 pm   #22
PJL
If you want to go for the 150 wiring then there is no alternative but to put the leaves in a different order as the No.4 connects TR to TS when on hook and these leaves are connected direct.
If its not possible to rearrange the leaves to create the 150 configuration then you can swap the bottom (1st) and 3rd leaf so that TR to TS is disconnected on hook. Connect leaf 5 to TS and leaf 6 to D. Leaf 1 and 4 should not be connected.
PJL is offline
Old 16th May 2017, 4:06 pm   #23
ThePillenwerfer
ThePillenwerfer's Avatar
Because we are fairly local to each other Sitwell brought his 'phone for me to look at.
Unfortunately I couldn't do it on a 'While you wait' basis, probably because I'm not used to working for an audience.
However, when alone I got it working.
ThePillenwerfer is offline
Old 16th May 2017, 4:15 pm   #24
Dave Moll
Dave Moll's Avatar
As a matter of interest, are you (and Sitwell) willing to share what the problem was.
Dave Moll is offline
Old 16th May 2017, 4:25 pm   #25
ThePillenwerfer
The only problem was it's not seeming to be exactly a 150 or a 12.
There were signs of poor soldering on the tags on the back of the terminals so that probably explains it. Also, some of the nuts and bolts that form the terminals are nickel-plated and some plain brass so I think we can put it down to the Phantom Fiddler.
I can also confirm that the "150" has a horizontal line stamped through it and "No 4" above it.
Old 16th May 2017, 4:57 pm   #26
PJL
Good result as I could see this thread running for a while!
PJL is offline
Old 21st May 2017, 12:33 pm   #27
sitwell
Smile Re: Candlestick Telephone help.
Big thanks to Thepillenwerfer for help provided in getting it working successfully
sitwell is offline
