Old 12th May 2017, 9:34 am   #1
sitwell
Thumbs up Candlestick Telephone help.
Hi, I recently got hold of a candlestick. It actually has a 150 crossed out and a No.4 at the top, go figure? I have tried wiring to the 150 diagrams and its not working. Should it work as per a 150 markings ? It also has a No 12 dial instead of the No 10, but don't think that makes any difference. I think its a wiring problem, as I have had some response from it by moving wiring to different places, but nothing that works properly. I have heard please try again, and had it going through to operator once, but it wont ring. Yes I have the No 1 bellset. I was wondering if anybody had any other wiring configurations to try please.
sitwell is offline
Old 12th May 2017, 10:44 am   #2
ukcol
ukcol's Avatar
Default Re: Candlestick Telephone help.
There is some info in post 7 & 8 of this thread for using a 150 with a No. 25 bell set. I suspect you may already have seen that or something similar though.
http://www.vintage-radio.net/forum/s...d.php?t=121585
ukcol is offline
Old 12th May 2017, 5:23 pm   #3
ThePillenwerfer
ThePillenwerfer's Avatar
I think N250 is very hard to follow and the attached diagram is clearer.
I can't offer any further advice without knowing what the problem actually is.
ThePillenwerfer is offline
Old 12th May 2017, 8:44 pm   #4
Dave Moll
Dave Moll's Avatar
Is there any chance of posting images of how your pillar and bellset are currently wired? There's always a chance that one of us may spot something you've missed.
Dave Moll is offline
Old 12th May 2017, 10:24 pm   #5
Pellseinydd
Can you confirm that it is the 150 that is crossed out? It seems odd as a No 4 is an earlier candlestick that used local battery and neither did it have a fitting for a dial in the base. Far more like to have been a No 4 converted to a 150. Check how many springs are on the switch inside the pillar. A 150 should have three that bunch together when the receiver is lifted. If there are two sets of changeovers it is a No 4 . If there is a change-over plus a 'bunch' of three it is a Tele 156 - the later local battery candlestick which replace the No 4 and had a facility for a dial to be fitted. 150 and 156 are interchangeable - just that the 156 has the extra set of changeover contacts. Thus the circuit for the 150 and Bellset No 1 will work for the 156 + BS No 1. GPO diagram N4200 (http://www.samhallas.co.uk/repositor...4000/N4200.pdf ) is the diagram for connecting a Tele 150 to either a Bellset No 1 or the later Bakelite Bellset No 25.
Ian
Pellseinydd is offline
Old 13th May 2017, 4:09 pm   #6
sitwell
Hi Guys yes crossed out 150 and marked No. 4. It is marked inside as a No. 150 and tried to wire like this if you can see OK.
ID:	142531   Click image for larger version
ID:	142532   Click image for larger version
sitwell is offline
Old 13th May 2017, 4:51 pm   #7
sitwell
Not sure if this is how it works.
ID:	142534   Click image for larger version
Name:	wire schem 002.jpg
ID:	142535   Click image for larger version
sitwell is offline
Old 13th May 2017, 6:47 pm   #8
Dave Moll
Dave Moll's Avatar
Your diagram above rather worries me in that TR (the common return for the transmitter and receiver) doesn't appear to be connected to anything. Also, I'm unclear where the green, red and white leads are going after leaving the bottom of your page.
Are you using a bellset? If so, how is this connected? Or do you simply have the dial, transmitter and receiver connected in series across the line?
Old 14th May 2017, 10:14 am   #9
sitwell
This is where my ignorance comes in I have wired as I see it explained in the diagram. I am wrong somewhere I do not know how or why or what is what I am just trying to follow steps. The page I wrote out shows my wires going from a candlestick phone to a bellset No. 1 at the bottom that's where my wires are going to intermediate cords red from tr in phone to tr in bellset, green from r in phone to r in bellset and white in phone to L2 in bellset.
I wired from the information on bobs telephone files for a 150 as I saw it
sitwell is offline
Old 14th May 2017, 11:18 am   #10
sitwell
I haven't seen a 150 leaf set up so I don't know how its supposed to look. To me there looks to be 6 leaves and 2 change overs.
This is my bellset
If anybody has leaves from a 150 candlestick that they could post, so I could see if they're the same, would maybe help me out please.
sitwell is offline
Old 14th May 2017, 11:07 pm   #11
PJL
The colour coding on the 150 connections are correct when compared to the N250 drawing. The dial picture doesn't show the connections but the brown wire appears to be disconnected?
PJL is offline
Old 15th May 2017, 10:21 am   #12
sitwell
Hi PJL the brown wire was from something else and not connected to this job thanks for looking. I am hoping somebody would post a side on view of a 150 switch hook so I can see the leaves.
Cheers.
sitwell is offline
Old 15th May 2017, 12:01 pm   #13
PJL
http://www.samhallas.co.uk/collection/bits_candle_3.htm
My 150 was identical to this but yours sounds like a 4.
PJL is offline
Old 15th May 2017, 2:38 pm   #14
sitwell
Excuse the quality of the drawing this is how my leaves are inside, does it match a 150 if not is it wire able with this config for dial use etc
sitwell is offline
Old 15th May 2017, 9:57 pm   #15
PJL
The N104 document is here http://www.samhallas.co.uk/repositor.../0000/N104.pdf
However, your phone has a dial and the connections are consistent with a 150 so it has been converted already. Your No.4 has two changeover contacts and is probably already wired to provide the double contact arrangement required for the 150. You could post a better picture showing the connections from the switch and any links.
PJL is offline
Old 16th May 2017, 10:24 am   #16
sitwell
Thanks PJL I can see it is a No. 4 arrangement of the blades now I've have seen the diagram. There was nothing connected to the phone, there was a dial put in the base but no connection made, neither were the transmitter or receiver connected. I think it's just been cobbled together to make it look like it was a complete telephone.
My question is can it be got working like a 150 to a No. 1 bell set?
Name:	stem pic 001.jpg
ID:	142653   Click image for larger version
Name:	stem pic 002.jpg
ID:	142654   Click image for larger version
Name:	stem pic 003.jpg
sitwell is offline
Old 16th May 2017, 12:19 pm   #17
sitwell
is it has not been made to work as a 150 in my opinion the blade contacts need altering and I dont know how to do that
sitwell is offline
Old 16th May 2017, 12:42 pm   #18
PJL
It may be made from the same parts and reassembling the leaves in a different order might convert it. Otherwise you will need to use the two break contacts but the original is designed to connect the receiver first.
The TS and TR connections are made by the leaves, the D connection is wired underneath. The order of the leaves is TS, TR then D. TS should be the longer one as in the pics provided by the link in post #13.
PJL is offline
Old 16th May 2017, 12:56 pm   #19
sitwell
thanks pjl is any chance of a pic of the leaves side on
sitwell is offline
Old 16th May 2017, 1:05 pm   #20
ThePillenwerfer
OK, I've looked at the diagrams and THINK this'll work. No promises though.
The red numbers on the diagram refer to the white ones on your photo.
Name:	Tele150 w Tele 12 GS.png
ID:	142668   Click image for larger version
Name:	Tele 12 GS.jpg
