Old 3rd May 2017, 5:44 pm   #1
David Simpson
Default DONG KWANG Freq. Counter FC-2200H
Does anyone know anything about this 5.5" x 1" x 3.5" diddy wee Freq. Counter please ?
I've just been given it. Supposed to have a range of 2KHz to 220MHz. It needs +12V un Regulated and +5V Reg, & Gnd, seemingly.
Regards, David
Name:	DONG KWANG FC-2200H.jpg
ID:	142038   Click image for larger version
Name:	DONG KWANG FC-2200H(b).jpg
David Simpson is online now
Old 4th May 2017, 1:26 am   #2
karesz*
Default Re: DONG KWANG Freq. Counter FC-2200H
Hello David,
only one of them to see_and lot of "waste"...
Karl
karesz* is offline
Old 9th May 2017, 4:25 pm   #3
David Simpson
Well - this wee counter has found a permanent & useful home on my bench. Apart from the on/off push button on the left, it has another three function push buttons on the right :- "HF -455KHz", "HF", & VHF.
Pressing the -455 button obviously being used when determining an LO frequency. (Providing, of course, that a commonly used IF of 455KHz is being used in a particular set under test).
So its now connected permanently to the o/p of my AVO AWO which I generally use for basic radio work. Its amazingly jolly stable frequency-wise for such an old item.
Pictures show the AWO putting out 456KHz, then the diff. of 10 KHz being shown when the button is pressed. Supply for the Dong Kwang is taken from the nearby 12/24V DC workshop supply(rigged as a boats supply with up to 50A/24V from a Sailor 1000 Series PSU/ Battery Supply).
Regards, David
Name:	Dong Kwang (a).jpg
ID:	142295   Click image for larger version
Name:	Dong Kwang (b).jpg
ID:	142296   Click image for larger version
Name:	Dong Kwang (c).jpg
Old 21st May 2017, 10:15 am   #4
David Simpson
Acquired the wee instruction booklet at last. David
Old 21st May 2017, 10:38 am   #5
karesz*
Fine that you got it!
David, Can you scan/post only the schematics with better readibilty please?
Thanks in advance.
Regards Karl
karesz* is offline
Old 21st May 2017, 11:42 am   #6
David Simpson
Will try again Karl. David
Old 21st May 2017, 2:06 pm   #7
karesz*
Thank you David!
Have nice time _ Karl
karesz* is offline
Old 21st May 2017, 2:29 pm   #8
One of those (oh too rare these days) simple, pretty, does what it says on the tin bits of test gear. Love it!
