Old 18th Jan 2017, 11:45 am   #1
Dickie
Default Murphy A100 Fixings
I thought I'd pick this one off the pile as there is a bit more to do than "change all the waxies". As you can see it's in quite a poor state, with some damage to the top of the cabinet. This shouldn't be too difficult to repair with some moulded epoxy and paint to cover it all up.
The problem I have is that the base was held on with masking tape, none of the four fixing screws being present. All I have to go on are the 4 0BA studs moulded into the inside of the case. Thankfully they are in good condition. Could some kind soul post a photo of what the original fixing screws look like, and how isolation between the chassis and screw heads is achieved. I'm sure I could fabricate something to do the job, but it would be nice if I could get it near the original.
ID:	136113   Click image for larger version
ID:	136114   Click image for larger version
Regards,
Richard, BVWS member
Dickie is online now
Old 16th Apr 2017, 7:55 pm   #2
robin coleman
Default Re: Murphy A100 Fixings
Good evening. I have just purchased one tonight. When I start on it in a few weeks I will report back my findings.
Regards
Robin
robin coleman is offline
Old 17th Apr 2017, 4:32 pm   #3
Dickie
After reading the manual I concluded the pillars were 0BA tapped Hex. cross-section made from sort sort of insulator. So I fabricated some from some plastic rod I had available and guessed the length by trial and error. It would be useful to know what the originals were, all the same. Here's a couple of shots of the finished radio, after a lot of rust removal, capacitor replacement, and loudspeaker cone reconstruction. It has to be one of the worst radios I have had to work on, everything is squashed in far too tight. Quote from the manual: "The compact layout of the A100 receiver has not been achieved at the expense of accessibility and, provided that the correct procedure is adopted, any component can be removed quite easily" which is another way of saying there is only one way to take it apart, and one way to put it back together.
ID:	141108   Click image for larger version
Regards,
Old 17th Apr 2017, 5:33 pm   #4
phil3153
WOW ,great job well done.
phil3153 is offline
Old 17th Apr 2017, 5:42 pm   #5
Boater Sam
That the one with a tuning knob missing Robin? I was considering buying and making a knob but someone had more cash to spend!
Boater Sam is offline
Old 24th Apr 2017, 9:54 pm   #6
robin coleman
Yes it is the one with the tuning knob missing, I did not notice it at the time. It also has its voltage selector part missing, so I will be looking for one. It also has a white lead in the mains lead and a black and green wire which I presume on is the aerial. The mountings are like the pcb hex spacers you used to buy from Elektor.
Regards
Robin
Old 28th Apr 2017, 2:35 am   #7
marconi_pete
marconi_pete's Avatar
You've done a brilliant job. Well done
Thanks,
Peter
marconi_pete is offline
