18th Jan 2017, 7:04 pm | #1 |
Mangled tonearm in a Hacker Gondolier - advice please
My little study seems to be turning into a refuge for mistreated examples of the output of the Hacker factory lately. This is the third example in two months. The tonearm on this SP25 Mk111 has had a hard time! One of the pivot screws is missing its little pivot pin - I can probably get over that with a little araldite and the sharp end of a drawing pin but the advice I need is about straightening the counterweight end. There appears to be some sort of rudimentary de-coupling going on? And I don't know what's inside. Should I just bite the bullet and bend it or do I need to be more subtle than that?
'....don't go mistaking Paradise for that home across the road!' (Bob Dylan) |
18th Jan 2017, 7:10 pm | #2 |
Re: Mangled tonearm in a Hacker Gondolier - advice please
More subtlety needed! Take the end cap out, push a drill bit of a similar ID into the open end, insert until just before the bend and then gently straighten it. Best to lift up the deck to do this.
Edward. |
18th Jan 2017, 7:20 pm | #3 |
Desolder wires from tagstrip and completely remove arm.
Withdraw the metal strip from end of arm and remove rear sleeve. Straighten metal strip in a vice. Reassemble in reverse order. Use epoxy resin glue to retain strip if loose in tube. |
19th Jan 2017, 12:43 am | #4 |
Thank you gents - that looks like good advice - I shall report back. The rest of this little survivor looks promising - warmed up with a variac and definitely alive.
21st Jan 2017, 11:58 am | #5 |
I can do you a pivot screw as I have a few scrap Garrard Decks lying around. Just PM me your address details.
21st Jan 2017, 12:34 pm | #6 |
Most kind - PM sent
21st Jan 2017, 8:26 pm | #7 |
Will search out the screw on Monday when I am back in the workshop
22nd Jan 2017, 9:13 pm | #8 |
Many thanks Nigel.
