18th Jan 2017, 2:02 pm | #1 |
New use for old tech!
http://uk.rs-online.com/web/p/barrie...32333435343126
Looks like it might well have other more retro applications than the one it's marketed for.
18th Jan 2017, 2:27 pm | #2 |
Re: New use for old tech!
That's inspired! I take my hat off to whoever thought of it, and I hope they sell lots...
Chris
18th Jan 2017, 2:37 pm | #3 |
Sign of the times- they've gone from dual-in-line to quad package....
Interesting- though how much longer will leaded components be around for them, or did the market analysis suggest plenty of NOS? |
18th Jan 2017, 3:15 pm | #4 |
Those are rather good. I still like using tag strips for power supplies. Thanks for the heads up on this.
18th Jan 2017, 4:36 pm | #5 |
It appears to be rate for <=12V so not much use for valve stuff
18th Jan 2017, 6:59 pm | #6 |
I guess the voltage rating is determined by the creepage distance. I suppose punching out alternate tags would be a solution.
18th Jan 2017, 7:21 pm | #7 | |
Pragmatically, punching-out intermediate tags would make the resultant inter-tag voltage rating 24V ! |
18th Jan 2017, 7:55 pm | #8 |
Seems like a rather timid case of CYA to me- what they mean is "if you use this for even 24V control gear, never mind anything higher and especially mains, then don't come crying to us when it goes wrong".
18th Jan 2017, 8:15 pm | #9 | |
I agree that the voltage rating between alternate tags should be 24V if the intervening tags are left in place.
18th Jan 2017, 8:36 pm | #10 |
I suspect that the rating was determined simply by what they tested it with, or just enough for the Raspberry pi application.
It would have to be an amazingly fine spacing to limit it to 12v and the control of production tolerances to avoid shorts would have to be even more amazing. David
18th Jan 2017, 11:42 pm | #11 |
It says the base is SRBP and the pitch is 6mm. So about 8mm between tags if intermediates are removed, which is greater than the inter-pin spacing of many valves.
19th Jan 2017, 1:53 am | #12 |
For functional (as opposed to safety) insulation, a couple of millimetres creepage distance between tags is good for 500V. Tagstrip spacing requirements haven't recently increased
19th Jan 2017, 5:09 pm | #13 |
I like it, even if not used with a PI, having 40 tags would be good for birds nest and deadbug construction. I agree the 12 volt "limitation" is just CYA.
worried about the electrons entering the circuit and the smoke leaving Andrew |
19th Jan 2017, 5:22 pm | #14 |
I had to look up CYA, "cover ones bottom" is my interpretation.
19th Jan 2017, 7:20 pm | #15 |
I think this RS item is a real oddball idea!
If its real purpose is a breakout board to allow experimenters to access the 40 lines of the Raspberry Pi its a very clumsy method. Whilst it might have mounting holes to enable it to stack it would then make access to its mother board difficult. The slot seems totally pointless, if the ribbon cable is fed up through it and then divided and wired to each of the tags the result would be a rats nest obscuring the silk screen text. Much better would be to split the cable under the tagboard and bring each wire up through the holes in the tags leaving the top surface clear. I don't have a Pi but presumably the function of the 40 connections are known, so I wonder why did they not mark the silkscreen to identify the i/o lines etc. I would have thought that a single side board with a footprint for the 40 way header taken out to a pattern of large plain pads that wires and components could be tacked on to would be a more practical and cost effective solution (like some 1970s prototyping boards). If money was really tight the pads would be undrilled so the PCB would only need as few as 44 holes. That my take on it anyway. Ian |
19th Jan 2017, 7:22 pm | #16 |
Agreed. It's an awful idea for what it's intended for. I can see a million other uses though.
19th Jan 2017, 7:32 pm | #17 |
I have been meddling with electronics and prototyping things for over sixty years, I did use tagstrips a long time ago but cannot visualise using them for anything nowadays. What sort of applications can you see? (I don't think the mods would appreciate if you listed a million here!)
Ian |
19th Jan 2017, 8:14 pm | #18 |
I still use the 2-rows-of-tags strips like this for a lot of 'hack' transistor-and-discrete-components things: my latest involved drilling the SRBP between the rows of tags to take a couple of NKT404 transistors as a low-power push-pull inverter.
