Old 14th Jan 2017, 3:08 pm   #1
jlaldridge
Default Rediffusion televisions
Hi. I have just acquired a mid 60s dual standard Rediffusion television, which I am picking up this week. Does anyone know whether it can be used with a video recorder on the 625 line setting to get a picture, or does it have to run on the obsolete Rediffusion cable system, or is there some way of adapting it? Thanks, James.
jlaldridge is offline
Old 14th Jan 2017, 3:23 pm   #2
G6Tanuki
G6Tanuki's Avatar
Default Re: rediffusion televisions
Rediffusion didn't only do TVs for their "cable" service; they also sold and rented out ordinary plug-an-aerial-in type TVs.
If yours is one of the latter then it should work with a VCR.
G6Tanuki is offline
Old 14th Jan 2017, 4:59 pm   #3
MALC SCOTT
MALC SCOTT's Avatar
If it is a cable only set you will need a Rediffusion frequency translator.
Malc Scott
MALC SCOTT is offline
Old 14th Jan 2017, 5:22 pm   #4
Nicklyons2
Nicklyons2's Avatar
Default Re: Rediffusion televisions
I would think, with a circuit, it would be fairly easy to fashion a baseband interface so that composite video and audio could be fed to the set regardless of whether it is cable or aerial. Of course safety isolation will have to be considered
Nicklyons2 is offline
Old 14th Jan 2017, 6:45 pm   #5
jlaldridge
Thank you, the way the Rediffusion cable system works seems most interesting, I believe that the channels where selected by a switch on the wall. Presuming I can get the set to work of course, what are the chances of getting a frequency translator or are they like gold dust?
Old 14th Jan 2017, 8:06 pm   #6
Dave Moll
Dave Moll's Avatar
There is a fairly extensive discussion of the Rediffusion cable system in this thread.
Dave Moll is offline
Old 15th Jan 2017, 1:34 am   #7
MALC SCOTT
MALC SCOTT's Avatar
They turn up on auction sites.
Malc Scott
Old 15th Jan 2017, 6:07 pm   #8
McMurdo
McMurdo's Avatar
weren't the settop boxes made by Thorn? Had a matching circular connector on the back
Kevin
McMurdo is offline
Old 15th Jan 2017, 7:01 pm   #9
MALC SCOTT
MALC SCOTT's Avatar
Rediffusion made their own.
Malc Scott
Old 15th Jan 2017, 8:28 pm   #10
julie_m
We don't know for certain yet that it isn't a Rediffusion-badged broadcast receiver. They certainly existed. Ask anyone who's been hit by a flying power button .....
julie_m is offline
Old 15th Jan 2017, 10:14 pm   #11
Oldcodger
In laws had this system where channels were selected by switch, using a Rediffusion set, but we lived close by with rediffusion network to our premises and it was possible to get a convertor ( I'd suspect modulator) to convert the Rediffusion signal to UHF.
Oldcodger is offline
Old 20th Jan 2017, 12:26 am   #12
whyperion
Following my previous threads with the In-Laws Rediffusion TV that Colourstar started to re-cap and ended up with problems of picture ballooning I have found in the paperwork this , which could have fallen out of the set, (or maybe it belongs to something different). I have scanned, and red printing on a damp paper does not have good contrast so auto adjusted and its nearly readable. If anyone wants to better scan, or my larger source file, let me know and I will try.
ID:	136167   Click image for larger version
ID:	136168   Click image for larger version
whyperion is offline
Old 28th Jan 2017, 4:59 pm   #13
jlaldridge
hi ,have now picked up the television so thought I would put up a few pictures of it for those interested, It is a rediffusion only set , but is in amazingly good condition, unmarked cabinet and all appears original except a couple of valves. now all i need is to check it over and find a frequency translator.
ID:	136612   Click image for larger version
Old 28th Jan 2017, 5:37 pm   #14
MALC SCOTT
MALC SCOTT's Avatar
Looks like a Mk8 cable set.
Malc Scott
Old 29th Jan 2017, 7:24 pm   #15
jlaldridge
have started work on this today , the model number says RVS 2d1983. don't suppose anyone has a circuit diagram or service data for this set??
Old 29th Jan 2017, 7:49 pm   #16
FERNSEH
FERNSEH's Avatar
Service information for the Mark 8 can be found in the 1963/64 Radio and Television servicing book.
DFWB.
FERNSEH is offline
Old 29th Jan 2017, 9:20 pm   #17
jlaldridge
thank you , have just found myself a copy on Amazon
Old 30th Jan 2017, 1:19 am   #18
FERNSEH
FERNSEH's Avatar
An example of the service information of the Mark 8 that can be found in the 1963/64 R & T servicing book.
DFWB.
FERNSEH is offline
Old 30th Jan 2017, 7:37 am   #19
ted_ntsx
ted_ntsx's Avatar
Location: Winterton-on-sea, Great Yarmouth, Norfolk, UK.
Ha! Now that brings back memories...
Ted.
ted_ntsx is offline
Old 3rd Feb 2017, 8:47 pm   #20
dseymo1
We had an identical one at home in the early '60s. This is the only other example I've ever come across. Considered quite a luxury set at the time, I believe.
As a child, I amused myself by setting the system switch incorrectly to see the patterns generated.
dseymo1 is offline
