13th Jan 2017, 3:11 pm | #1 |
No Longer a Member
Dropping filament voltage for a valve
The repair of my recent Hunts CRB3 acquisition has gone better than expected. I only needed to replace the electrolytic filter capacitors and get an EM34 magic eye (a resonably priced and tested one from Mullard Magic - thanks!)
The capacitor and resistor measurements are all good on the CRB3. I haven't tried any of the other functions so maybe there will be a fault there somewhere. One thing I have noticed is that the filament on the EM34 has 6.95V across it. I would like to drop that down to 6.3V. Not having done this before, do I want a resistor in series or should I put one in parallel with the filament? Initial thoughts suggest series but I want to check with wiser heads. Thank you. |
13th Jan 2017, 3:22 pm | #2 |
Re: Dropping filament voltage for a valve
Assuming that the set uses parallel transformer fed 6.3v valves, you would use a resistor in series with the magic eye heater. You need to know the current taken by the valve heater, and you can work out the voltage drop required, so by simply using ohm's law you can calculate the resistor value required. One thing to bear in mind is that your meter may not be totally accurate on AC, and also I'm not sure how tolerant valves are to a bit of variation in heater supply voltage, hence it may not be worth adding the resistor. Mains supply voltage variations may also come into play.
13th Jan 2017, 3:32 pm | #3 |
assuming the values you have given are correct:
heater current = 0.2A voltage present = 6.95v required voltage = 6.3v voltage drop required = 6.95-6.3 = 0.65v r = v/i r = 0.65/0.2 r = 3.25 ohms closest preferred value = 3.3 ohm p = i*i*r p = 0.132 watts or greater and yes the resistor should be in series with the heater.
If it can be built, it can also be fixed. |
13th Jan 2017, 3:40 pm | #4 |
This is the only valve in the equipment, I think?
Is the mains transformer on the correct voltage tapping, if so provided?
13th Jan 2017, 4:30 pm | #5 |
No Longer a Member
Yes, only the one valve.
There is no mains selector. It was built just after 1959, judging by the dates on the two pots, so the mains voltage has probably increased since then. |
13th Jan 2017, 7:37 pm | #6 |
I wouldn't worry, the screen will degrade much faster than the cathode.
13th Jan 2017, 9:49 pm | #7 |
It's only 10% out. That's within tolerance; valves were rated ±20%.
15th Jan 2017, 12:52 am | #8 |
I think valves were often rated 10% but with 5% recommended. For optimal life, the voltage should be spot on or (for tubes that don't easily suffer from cathode poisoning) slightly lowish. I tend to agree however, that the target is likely to degrade faster, if used full on for most of the time.
