Old 12th Dec 2016, 12:11 am   #1
keithinuk
Default 706L accessories switch
I have a 61 706L with an off on switch, I have had them on other phones and use then as a mute switch mainly.
This one as per normal has had all the wires cut to the switch and has had a basic rewire.
But strapped to the switch looks to be a bulb, small and thin.
If it is a bulb, what would be the point of it, as I wouldn't have thought it could be seen though the phone.
keithinuk is offline
Old 12th Dec 2016, 2:38 am   #2
jjwayle
Default Re: 706L accessories switch
Not by any chance a very thin clear glass bulb? Could be an early thermistor to stop bell tinkle on party lines, common on the black 312 i think bakelite phones but usually by the 706's the thermistors were a black plastic blob with a couple of black leads. Other than that could be a non standard mod where someone else has bodged the phone to do something else e.g. house to shed set up?
jjwayle is offline
Old 12th Dec 2016, 3:18 pm   #3
keithinuk
Thermistor you say, I looked it up and found, Shared-Service Adaptor, used on the 706.
Which look very much like what it is.
Thanks.
Old 12th Dec 2016, 5:36 pm   #4
jjwayle
Yep thats a thermistor, early style! Must have come from a set up where the phone was on a party line!
jjwayle is offline
