Old 14th Dec 2016, 11:38 pm   #21
FERNSEH
FERNSEH's Avatar
Default Re: A scary Baird T23.
More Scaryness. The mirror lid has been removed along with the wooden screen aperture and mask. The tube looks even more intimidating! The next stage is to lift the horned bomb up and away from its mounts.
The plan is to tilt the set forwards at about 30 degrees for easier removal of the tube.
DFWB.
ID:	134418   Click image for larger version
FERNSEH is online now
Old 15th Dec 2016, 11:44 am   #22
Heatercathodeshort
Heatercathodeshort's Avatar
We could make 'Carry on Cossor' with all this Wendy Woo business David. Get on with it!
The 65/2 has a cloth bag dagged to the bulb presumably to stop bits of glass flying around when it implodes... Your early 65K looks as if it has lost its frock or was never fitted for one. John.
Heatercathodeshort is offline
Old 15th Dec 2016, 5:29 pm   #23
bobhowe
bobhowe's Avatar
Hi was in the shop yesterday looking at this wonderful set & tube a bit scary but us Northerners are made from the hard stuff ( for the cold weather we have here ) & David will have it up & running soon with adapter plates regards Bob
bobhowe is offline
Old 15th Dec 2016, 6:38 pm   #24
peter_scott
peter_scott's Avatar
When they are less horny you can play at balancing them on their small ends!
http://members.iinet.net.au/~cool386...dumont_crt.jpg
Peter
peter_scott is offline
Old 15th Dec 2016, 11:48 pm   #25
FERNSEH
FERNSEH's Avatar
The tube is out at last! Easy job to lift it out after all. Instead of trying to manoeuvre those "horns" through the metal cradle plate the trick is to remove the tube up by using the plate to lift the tube up and away from the cabinet.
The next stage is to make the cutouts in the original CRT mounting board to give adequate clearance for the horns.
DFWB.
ID:	134480   Click image for larger version
Old 16th Dec 2016, 1:17 pm   #26
FERNSEH
FERNSEH's Avatar
Bad news. The Cossor 65K/2 has a different shape bulb and will not fit in the T23. In order that it could be made to fit in the Baird T23 extensive modifications are necessary and no doubt this can done. However, there is three Cossor 65K tubes upstairs, one I know to be useless because it was removed from the T23 many years ago. The other two, who knows? Might as well take a chance and fit one later today, but first there is all that tidying up to do to the CRT mounting arrangements.
DFWB.
Old 16th Dec 2016, 2:12 pm   #27
bobhowe
bobhowe's Avatar
Hi David what a shame it won't work can you test the other 2 tubes like you did a while back with a crt using a eht supply & lt for the heater regards Bob
bobhowe is offline
Old 16th Dec 2016, 2:23 pm   #28
FERNSEH
FERNSEH's Avatar
Hi Bob, the Cossor 65K has a 4volt heater and has the usual indirectly heated cathode whereas the original Baird Cathodevisor 15MW1 has a 2.5volt directly heated cathode. I've picked one of those 65K tubes from the collection upstairs and it might have some potential of showing a picture of sorts. The is still some silveryness about the getter so why not give it a try?
DFWB.
Old 16th Dec 2016, 2:33 pm   #29
bobhowe
bobhowe's Avatar
Yes i would give t a try would be nice to see this working again with a brighter picture regards Bob
bobhowe is offline
Old 16th Dec 2016, 4:22 pm   #30
FERNSEH
FERNSEH's Avatar
And here is the tube as it was delivered in 1993 in the Shore Porters box.
How's that for an old company, established 1498!
DFWB.
Old 16th Dec 2016, 5:25 pm   #31
Tractionist
Mmmmmm .......
There are outfits in the States that will fully refurbish tubes of this vintage - new guns/phosphors/dag etc. (At what price who knows?)
(David is a Geordie .... so he does 'why aye' a lot - but he invariably gets the job done ... to a superb standard !!)
Red to red, black to black. Throw the switch and stand well back!
Tractionist is offline
Old 16th Dec 2016, 5:59 pm   #32
FERNSEH
FERNSEH's Avatar
Hi, Why aye indeed but what would be cost of sending a tube over to the States? I quite like this set even if was a badly made load of junk when I first acquired it way back in 1993. Over the years I've tidied it up to a standard it should have been in the first place.
Certainly would be great to see a clear bright picture on the screen. The TRF unit does a good job resolving the 2.5Mc/s definition bars. Not bad for 1938.
Anyway, let's find out if the spare 65K tube is any good.
DFWB.
Old 16th Dec 2016, 10:59 pm   #33
FERNSEH
FERNSEH's Avatar
But before the replacement tube is installed the CRT mounting board needs some attention, notice those crude cutouts for the CR tube's horns. More clearance is required and a more professional looking job done as well.
Also noteworthy are the extended pole pieces from the frame timebase oscillator transformer. Baird Television Ltd. applied this method of vertical deflection on all the companies' pre-war sets.
Some speculation whether this type of timebase was developed by BTL or Fernseh A.G.
DFWB.
Old 17th Dec 2016, 11:23 am   #34
Oliver35
Oliver35's Avatar
I was wondering why there only appeared to be one set of deflection coils- what a bizarre technique. Was there an advantage to be gained by doing it thus, or was it just Baird being wilfully idiosyncratic?
Oliver35 is offline
Old 17th Dec 2016, 11:26 am   #35
ianm
ianm's Avatar
Hi Tractionist,
May we have details of these outfits, please? Thanks.
Regards
Ian McLaughlin, BVWS member
ianm is offline
Old 18th Dec 2016, 12:41 pm   #36
FERNSEH
FERNSEH's Avatar
Cut outs made in the original CRT mounting board to clear the "horns" on the Cossor CRT. Don't really like doing this sort of thing to an almost eighty year old TV set but it's either that or a possibly damaged CRT. If in the very unlikely event a serviceable Cathodevisor 15MW1/2 tube ever turns up an almost exact replica of the CRT board could be made.
DFWB.
Old 18th Dec 2016, 12:55 pm   #37
Nuvistor
Nuvistor's Avatar
You have to work with what's available, far better to lose a bit wood than the irreplaceable CRT.
It's coming along nicely.
Frank
Nuvistor is offline
Old 18th Dec 2016, 1:25 pm   #38
Heatercathodeshort
I'll second that. It's only a bit of wood after all. J.
Old 18th Dec 2016, 1:40 pm   #39
peter_scott
I don't like modifying original stuff either but I agree that this is the right path to follow.
Peter
Old 19th Dec 2016, 11:44 am   #40
FERNSEH
FERNSEH's Avatar
Tube mounting assembly is ready to accept the replacement CRT.
DFWB.
