5th Dec 2016, 2:31 pm | #1 |
Small glowing tube/lamp
When I was young, I remember regularly taking the cover off our conventional dial telephone (usually when mum and dad went out) which in the early 1970s was just one standard phone in the hallway. I noticed though there was a small black coated tube which was wire ended, and on parts of it the coating would be worn off, or fallen off, so I could see inside the little holes, and what I saw was a tiny orange glow like a valve, when the handset was lifted. So what is this little lamp, what is it called and what does it do? Thanks, Paul. |
5th Dec 2016, 2:37 pm | #2 |
Re: Small glowing tube/lamp
It was a barreter which formed part of the regulator circuit housed on a plug in PCB.
5th Dec 2016, 2:45 pm | #3 | |
There're apocryphal tales of worried old ladies dunking their telephones in water (or somesuch) upon seeing the glow from within and thinking their telephones were on fire, in the days before the bulbs were painted black or covered up.
Regds, Russell W. B. G4YLI. |
5th Dec 2016, 3:10 pm | #4 |
Thanks graham, thanks russell, wow that's a good old story about the old laddies dunking the telephone! brilliant
Paul. |
5th Dec 2016, 3:13 pm | #5 |
Fascinating, you learn something every day.
5th Dec 2016, 4:32 pm | #6 |
The version I heard (which seems more likely) is that the bulb was painted black because the GPO were worried subscribers would see the glow and think the telephone was on fire, not that anybody actually _did_ think their 'phone was on fire.
706 type telephones (separate plug-in PCB for the regulator) normally have one bulb with 3 leads, a centre-tapped fillament. The 746 has 2 bulbs with 2 wires each in a plastic holder, they are wired in series externally to give much the same circuit. I have seen a 706-style plug-in PCB with the 2 bulbs and holder from a 746 on it. No it wasn't a bodge, it looked original. |
5th Dec 2016, 4:57 pm | #7 |
I heard the black paint was added because the GPO feared people might use the light to read something by, without paying them for the added functionality
7th Dec 2016, 1:13 am | #8 |
Maybe nowadays you could hijack enough post office electricity using a switching converter to drive a high efficiency LED without tripping the line
