19th Dec 2016, 7:14 pm | #41 |
Re: R.F. voltmeter: your thoughts, please
Al, please remind me/ us -- what do you have in mind for this probe in particular? There seem to be so many excellent designs suited for dizzyingly above as well below 100Mhz!
Al |
19th Dec 2016, 8:40 pm | #42 | |
If you fed in 10V rms to the meter then the detector output would be about -28V DC. If the operator then set the range switch to the mV range by mistake then the JFET gate would presumably be fed with -28V DC directly rather than via the resistive divider. There will be typically about +2V on the JFET source. This is a bit marginal in terms of Vgs breakdown voltage but some devices can withstand this. But a typical opamp (or an instrumentation amplifier?) running a single rail would get zapped by this huge negative voltage at one of its inputs. I think you may have to use a split supply opamp anyway to get the offset trimming to work well but you would have to provide some form of limiting to stop the opamp from being fed (detector output) voltages below the negative supply. Some opamps can't tolerate more than about a volt below.
Regards, Jeremy G0HZU |
19th Dec 2016, 10:04 pm | #43 |
Thanks for the comments on the issues with the op-amp.
In post #15, Al gave a link to the original article in '73 magazine' inspiring this thread, and I'm just in the process (53MB) of downloading that. I encourage others to do likewise, if only to see the front cover (December 1973), which is wonderfully incorrect and well worth $1 . The circuit shown in the OP is interesting in that it squeezes in no less that 4 detector diodes in to the probe in what still looks to be a doubler, whereas the Marconi circuits, which drew attention in previous threads, were voltage doubler circuits using two diodes. I don't know whether Al was intending to put one of the Marconi probe designs in front of the amp circuit shown, or whether he was interested in keeping the probe and the amp just as shown. I'm sure I had picked up the suggestion somewhere, that while using more complex rectification circuits in RF probes does increase the detected voltage, there can be downsides to these circuits in the form of "anomalous" responses - resonance effects? B Last edited by Bazz4CQJ; 19th Dec 2016 at 10:10 pm. |
19th Dec 2016, 10:32 pm | #44 | |
There are 4 diodes in the detector head but only two of the diodes are used as the doubler/detector. The bottom two diodes are just there as (passive) thermal tracking diodes to help with the temperature compensation. I think both sets of diodes will be biased at a couple of uA and the idea is that any bias change in the 'real' detector pair due to temperature changes will be cancelled by the passive pair of diodes in the head.
Regards, Jeremy G0HZU Last edited by G0HZU_JMR; 19th Dec 2016 at 10:39 pm. |
19th Dec 2016, 11:13 pm | #45 |
Mmm..I'm going to have to plead guilty to having been slow to look at the 73 article, as having done that now, I appreciate Al's interest in the design.
All we need now is some suitably expert individual to come up with the n-channel design; perhaps he's doing that right now . Wasn't 73 good in the day? B |
19th Dec 2016, 11:51 pm | #46 |
There was also the American 'Ham Radio' magazine which was excellent and technically oriented for people who built their gear. This eventually got taken over by 'CQ' mgazine and turned into a sister publication carrying the more technical stuff under the name 'Communication Quarterly' And then that got taken over by the ARRL and rolled into their own 'QEX' technical magazine, the sister to QST.
The ARRL do a CDROM of past QEX which includes all of Communications Quarterly and a lot of Ham Radio. Also there's that American magazine archive site which I expect to have the whole lot. There is an awful lot of good amateur radio technical articles once you know where to look. These are not the usual 'here are the photos from our DXpedition' articles David
20th Dec 2016, 1:53 am | #47 |
In the article in 73, the author discusses his selection of Si over Ge diodes for the probe. He doesn't say whether the Ge ones were junction or point contact, but haven't the latter often been favoured for probes because of their low capacitance? His measured input cap was 4pF. Perhaps his requirement for an input range up to 10V excludes point contact? I wondered whether the author might still be around, but his callsign expired in 2004 .
B |
20th Dec 2016, 12:00 pm | #48 | |
It's really quite amazing just how little privacy one has these days, even world-wide, when wandering around the 'Net. Al. |
20th Dec 2016, 12:20 pm | #49 | |
This isn't the only design that is under consideration: there is also the design by G0WCA - which is under investigation. (But that's a topic for a different thread). Aside. As various members have pointed out, with any attempts to measure R.F. voltages - especially at high freqs. and from moderately high-Z sources - things can get a bit difficult: cct. loading, etc. But that doesn't mean that such a measuring device is not worth having: simply an awareness of its limitations when it is in use. An obvious example of that is the humble X10 passive 'scope probe with a typical 'tip' capacitance of something like 15 pF. Al. |
20th Dec 2016, 12:30 pm | #50 | ||
Al. Last edited by Skywave; 20th Dec 2016 at 12:31 pm. Reason: Add post reference |
20th Dec 2016, 5:37 pm | #51 | |
B |
21st Dec 2016, 12:02 am | #52 | |
What FET did you use - a 2N3819? Al. Last edited by Skywave; 21st Dec 2016 at 12:07 am. Reason: Add abridged quote. |
21st Dec 2016, 3:41 am | #53 |
Yes, I used a 3819 as per the original. And because I thought the FET might be vulnerable to damage, I put the FET in a holder rather than solder it in, which was probably a poor trade-off. I used a PCB, again as per original.
It's around 2 years ago since I built it, and it got put in the pending tray when it seemed that it didn't achieve the high frequency response which was claimed (I wanted to go to 146MHz min). Since you mentioned it a couple of days ago, I've got it back on the bench . The way he has the potentiometers for the 3 ranges in parallel - does that seem like an optimum arrangement? B |
21st Dec 2016, 5:12 pm | #54 | |
For a signal source, I used an HP8640B sig. gen., fed to the cct. via 50 Ohm coax, with a 50 Ohm termination at the end of that and then a very short piece of coax to the cct. under test. Measurements were made with a Tek. 2465 'scope via an HP X10 passive probe. Test freq. was 10 MHz; measurement results (as below) were subsequently found to be valid down to at least 1 MHz. For 20 mV p/p, at the gate; 18 mV p/p at the source; a tiny change in the d.c. level at cathode of D2 (the rectifying diode). For 200 mV p/p, at the gate; 180 mV p/p at the source; a change in the d.c. level at cathode of D2 (the rectifying diode) from 280 mV to (280 + 50) mV. For the two diodes, I use HP 2800-5802 'hot carrier' diodes. For the bias diode, I had 0.7 v. at its anode. The load on D2 was a 50 k-Ohm pot. - as per the original design. HTH, Al. |
21st Dec 2016, 6:41 pm | #55 |
OK, so it looks like your version with the BF256 is working as a unity-gain buffer to at least 10MHz, and from your earlier post, possibly up to ~40MHz?
For anyone who's interested, Skywave is working on the circuit attached, originally published by G0CWA on the net. In the original circuit, that feeds in to a CA3140 op-amp. In the original design, the FET is a 2N3819, and he claimed that it was good to at least 150MHz. My version was wasn't . B |
21st Dec 2016, 7:03 pm | #56 |
"good" can mean anything between 'has a specification and meets it' and 'confirms that something is there'
21st Dec 2016, 8:35 pm | #57 |
I recall playing with 3819's in GDO circuits a very long time ago and forming the opinion that something better was desirable to work comfortably at 2m, though it seemed plausible that a unity-gain buffer was possible. As for the meaning of 'good', maybe G0CWA had some 'really good' 3819's?
B |
21st Dec 2016, 11:17 pm | #58 | |
Al. |
21st Dec 2016, 11:38 pm | #59 |
The 2N3819 was probably the breakthrough device for JFETS.
As Al says, the pinch-off voltage Gm and Idss can have huge variations within the device's registered spec. Later devices weren't a lot better as made, but the manufacturers had different type numbers registered for different parts of the range so for any type number, the spread looked better at least. David
23rd Dec 2016, 10:01 pm | #60 |
I think the inspiration for the detector in the G0CWA circuit came from this web link
http://www.zen22142.zen.co.uk/Circui...tgear/rfmv.htm The test results for the linearity of the detector for small signals don't appear realistic to me. I would say they are in fantasy land as the performance claim seems to indicate this thing has the linearity of a precision rectifier at tiny signals. eg at a few mV . I would expect this detector to work in square law up to a few tens of mV and then gradually trend towards linearity on the upper range. Up at the higher end, 1.5V rms seems a lot to feed into that circuit with the 2N3819 so I would expect to see some issues at the upper end too. The input JFET circuit is far from ideal and will have issues of its own wrt its performance as a 1:1 buffer and how well it can drive the detector stage. The G0CWA meter also uses a linear scale and I don't think this detector/meter will be very linear. Also the design has no temperature compensation and also the JFET stage won't perform very well. The PCB layout is poor and the RF input connection and grounding doesn't look good. I remember this circuit from a recent thread and I thought it was so poor it wasn't worth analysing let alone building unless you just want something that works reasonably well as an RF indicator with a very casual dial calibration.
Regards, Jeremy G0HZU Last edited by G0HZU_JMR; 23rd Dec 2016 at 10:09 pm. |
