Old 25th Nov 2016, 8:14 pm   #1
Levente
Default Tandberg 64x after changing capacitors
Hello tube gear lovers.
I have a tape recorder Tandberg including tubes such ECC81 ECC82 ECC83. On one of the pcb where I have one ECC81 and one ECC82 opposite each other does not lit up at all when I switch the unit on. Others are fine... the other ECC81 is the strongest, then the ECC83s and the other one of ECC82 is the weakest.
I was going through this unit and replaced all of the miniprint caps, the electrolyt caps too. Some of the small Siemens caps next to the tubes and what I have is weak sound on the left channel even though the eagle eye is full on, R channel eagle eye is barely responding and nearly no sound at all. Also no sound on playback...
Not sure where to go from here but if any of you could point me a direction I would really appreciate it.
Tubes are replaced and should be working fine...
Thanks for any advice, i just don't want to give up on this beauty!
Levente is offline
Old 29th Nov 2016, 9:11 am   #2
radiotechnician
Default Re: Tandberg 64x after changing capacitors
Tubes in your machines are paired in series. If you have tested all the
tubes, and all were good, albeit weak, or not, then the pair not
lighted may have a crack in the print between the sockets, or at any
pin 4 or 5 termination.
If you cannot readily see any cracks, a DVM set to DC could be used to
trace the circuit with the power on. The circuit runs at 24 volts.
If you decide to do this, first remove the 0.2 A HT fuse. This will prevent
damage, should a probe slip. It also will be safer for you.
Steve Dow
VE7ASO
radiotechnician is offline
Old 29th Nov 2016, 9:42 am   #3
ricard
ricard's Avatar
My (fairly limited) experience with these machines is that leaky Miniprint (Rifa) caps can cause all sorts of weird problems. My advice would be to replace all the Miniprints you can find (with the possible exception of the ones on the indicator valve boards as they are really awkward to get at) and then retest the machine before doing anything else. One three of the four 64:s I've encountered this was enough to bring the machine up to spec. (Of course, you need to figure out any problems if the valves don't light up first, although with some valves it can be really hard to see them lighting up at all).
ricard is offline
Old 29th Nov 2016, 7:01 pm   #4
Levente
Thanks Radiotechnician...i will try my best. I had a look on one particular tube holder and if i move it around, it comes alive, sending signal to the opposite tube...the opposite tube lights up for a millisecond fully like a lightbulb and then goes back to a little lighting pins....kinda very light red color...
Hey Ricard....thanks again your reply. I have changed all the miniprints..thats was my first move....not sure what the problem is really...i was hoping that is the only problem with this but looks like no...maybe those Hunts paper caps for the bypass at the resistors... or maybe some resistors are also out...nothing else i can think of really...what the heck could be the problem, i am just guessing..
Thanks again for you both the help...could this be a resistor issue somewhere in the circuit?
Best,
Levente
Levente is offline
Old 30th Nov 2016, 1:23 pm   #5
radiotechnician
Some ECC83 tubes have a tendency to flash brightly on first
powering. It is harmless.
http://www.ebay.com/gds/Why-Mullard-...2972031/g.html
Steve Dow
VE7ASO
Old 30th Nov 2016, 3:39 pm   #6
ricard
ricard's Avatar
The contacts in the valve holders could have been damaged. I've come across a few where one arm of the fork that grips the valve pin had broken off, so that there was essentially no contact pressure. Wiggling the valve brought back temporary functionality.
Yes, there could be other capacitors, like the Hunts that have failed, although in these machines they are usually low value types and used in the equalizer circuitry so they affect the frequency response mostly. Another thing is as you say resistors, which can go high in value, especially composite anode resistors are prone to this, which lowers the anode current and the valve then isn't operating at its correct operating point.
ricard is offline
Old 1st Dec 2016, 6:53 am   #7
Levente
Default
Thank you radiotechnician for the info and the link...the only one brighten up when gets energized is one of the ecc81 Tungsram but i guess it is the same principal. I will go ahead and change one or two suspicious looking tube holders maybe that will sort out the issue. If not, i need to find a faulty resistor which will be a big task with my "current technical knowledge"
Thanks again and have a wonderful day!
Hey Ricard,
Thank you. I think I will get that dodgy looking one changed and see if that will fox the issue...if not, i will need to find a faulty resistor. Not sure where to start tho...there are soo many of them and finding the measures of those old ones....i got confused which way you read them....from the silver sparkly side or the brown one...
Thanks again Ricard, and have a great day.
Levente is offline
Old 1st Dec 2016, 5:56 pm   #8
martiR2R
Re resistors, it doesn't matter which way round you connect your meter but it is advisable to desolder one end otherwise the reading could be affected by other components in the circuit.
BVWS Member (lapsed!)
martiR2R is offline
Old 1st Dec 2016, 7:15 pm   #9
Levente
Thanks guys again for your inputs. I have attached a picture of the the playback amplifier board. There are 3 tube holders where the pins 4 and 5 has no continuity measured with a voltmeter. Is this odd right? I believe these pins should have connections with each other.
I am not sure why is this happening, maybe this is also could be the problem source. Interesting!
Name:	Tandberg faults.jpg
Levente is offline
Old 1st Dec 2016, 8:34 pm   #10
Station X
Station X's Avatar
Continuity is not measured with a voltmeter or with a DMM set to measure volts.
Are you saying that with the unit powered up and the valves plugged in, with your meter set to read volts, you are not measuring a voltage between pins 4 and 5 of the valveholders indicated?
Measure the DC voltage from chassis to pins 4 andd 5 of each vlveholder. Report the results here and someone will advise you.
Graham. Forum Moderator
Station X is online now
Old 1st Dec 2016, 8:37 pm   #11
Levente
Hi there. Thanks for the note. No I have set my multimeter to check continuity with the beep. 1 out of 4 is beeping at pin 4/5, the rest tube holders are not, that's why I thought there could be an issue.
Maybe I am completely wrong.
Levente is offline
Old 1st Dec 2016, 9:02 pm   #12
Station X
Station X's Avatar
Depends what your meter sees as continuity. Valve heaters will always have some resistance and are not a short-circuit.
Another problem is that even if a valve's heater is open circuit, you may still see continuity, or a resistance, via a parallel path through the other heaters.
You can check the heaters by removing each valve in turn and measuring continuity (LOW RESISTANCE) between pins 4 and 5 of the valve.
To test the whole heater chain(s) it would be better to measure voltage.
Name:	HEATER CHAIN.jpg
Old 4th Dec 2016, 11:41 am   #13
Levente
Smile Re: Tandberg 64x after changing capacitors
Thanks for the info. I have now changed the tube holder which had connection problems. Now the paralell tube also lights up. Still having the same problem. Very weak sound even tho the volume is full on. When I hit the record channel 1 and 2, the same weak sound and the magic eye indicator Left is not responding, the R one measures a full on max high volume (like in a peak)....
I read somewhere this is a phase reverse issue such:
This can be a bad 1/2 tube, a faulty socket contact, a broken or open plate resistor or coupling capacitor to the output tube, or a bad solder joint on any of these.
Thats all sounds good but which one is then...shall i change the coupling caps next to each resistors..or shall i change resistors? or am i still having a faulty tube?
I will measure the voltage this afternoon ...but .. runnig out of ideas and my knowledge on this is very limited...seems like a very complicated machinery to me...
Levente is offline
Old 4th Dec 2016, 11:46 am   #14
Station X
Station X's Avatar
Can you confirm that ALL the valves now light up please.
If so the next step is to take voltage readings and compare the results with those in the service sheet.
Old 4th Dec 2016, 12:24 pm   #15
Levente
Visually, yes....not sure how bright they should be, but the ecc83s and ecc82s has two little "dot" like on the their tops...the ecc81s are much much brighter...
Will measure the voltages this afternoon...i will measure against the ground i have in my flat..right?
So will use the ground from my electricity connector socket...
Levente is offline
Old 4th Dec 2016, 12:26 pm   #16
Station X
Station X's Avatar
Voltages should be measured between the chassis of the unit and the valve pin being tested.
Set your meter to a suitable DC Volts range.
Old 4th Dec 2016, 12:30 pm   #17
Levente
Thanks Graham. Will do. Shall I measure each pins of each valves just to see the measures? It will not exceed 250V range there right? As my voltmeter is only capable up too 250V...
Levente is offline
Old 4th Dec 2016, 12:31 pm   #18
Levente
just read your pervious message...and the answer is there...sorry...
Levente is offline
Old 4th Dec 2016, 12:40 pm   #19
Station X
Station X's Avatar
Here's the circuit for the valve part of one channel. You'll need to take voltage measurements on both channels.
Valve pins number clockwise from the gap when looking at the underside of the Printed Circuit Board (PCB).
Measure pins 1,2,3,7 and 8.
There should be zero volts on pins 2 and 7 the control grids.
Old 4th Dec 2016, 1:37 pm   #20
Levente
Hi Graham, here are my reading.
Staring with the playback preamp+cathod follower board:
Tube ECC83 #1
1: 273V (anode)
2:0 (grid)
3:0 (cathode)
4:0 (heater)
5:0 (heater)
6: varies..1400V, then 302 then 259V the steady 302V (anode)
7: 0 (grid)
8:0 (cathode)
9:0 (heater CT)
Tube ECC83 #2
1:256V
2+3+4+5= 0V
6: 252V
7: 253V
8: 0
9: 0
Tube ECC82 #1
1:275V
2+3+4= 0V
5: 35V
6: 296V
7+8+9= 0V
Tube ECC82 #2
1: 275V
2+3+4: 0V
5: 35V
6: 298
7+8+9= 0V
There record preamplifier and the record amplifier board
Tube ECC83 #1
1: 305V
2+3+4+5= 0V
6: 302V
7+8+9= 0V
Tube ECC83 #2
1:300V
2+3+4+5= 0V
6: 302V
7+8+9= 0V
Tube ECC81 #1
1: 309V
2+3+4= 0V
5: 35V
6: 315V
7+8+9= 0V
Tube ECC81 #2
1: 324/310 V
2+3+4= 0V
5: 35V
6: 315
7+8+9= 0V
I think there is something dodgy going on....
Levente is offline
