Old 9th Nov 2016, 8:01 pm   #1
fulham54
Default Goblin Teasmade 835 De Luxe
Hello
I have a noisy teasmade clock which ticks loudly and makes humming noise whereas before was quiet. I'm happy to try a small drop of sewing machine oil to reduce any friction but wanted some advice as where to apply it without dismantling the clock. Can this be dropped through small hole in the metal plate(brass coloured) attached to clock motor or do I need to unscrew this and oil from there.
I have tried to attach photo to allow you to highlight where to apply the drop of oil but struggling to attach on this phone.
Thanks for any advice.
fulham54 is offline
Old 11th Nov 2016, 9:35 am   #2
Mike Phelan
Mike Phelan's Avatar
Default Re: Goblin Teasmade 835 De Luxe
The noisy 835 clock can be because of the plastic worm. A small drop of oil will do no harm but it's often because of wear.
You'll need to dismantle it as far as where you can see the mechanism; where the plate mentioned is.
The 835 clock motor is its weakest point as it isn't quite robust enough to cope with years of use.
Mike.
Mike Phelan is offline
Old 11th Nov 2016, 6:31 pm   #3
fulham54
Thank you Mike. Helpful as always. Will try that.
fulham54 is offline
