Old 13th Dec 2016, 7:48 am   #21
MrBungle
MrBungle's Avatar
Default Re: Homebrew frequency counter
It is spot on that. I think the input impedance is quite low and at higher frequencies it is dragging the input low enough not to trigger it. I've designed a constant 10M impedance follower and Schmitt trigger that is good to 120MHz with 40mV input in LTSpice so will attempt to construct that at some point.
Motivation is dwindling though
MrBungle is offline
Old 15th Dec 2016, 3:12 am   #22
Terry_VK5TM
Terry_VK5TM's Avatar
Or use a FET input stage before the bipolar stage to up the input impedance?
Know what you mean re the motivation, mine keeps sliding and I have to give it a good kick to get it working again
Terry
Terry_VK5TM is offline
Old 15th Dec 2016, 10:11 am   #23
MrBungle
MrBungle's Avatar
That's roughly what I've sketched out. Got a FET follower with a back to back BJT clamp in front of it, a BJT follower, coupling cap, high gain amp to cause saturation at polarity change in the cap, then another follower. Schmitt trigger is gone; couldn't get it to work consistently. Works in LTspice so far. Hopefully reality will be close. Pushed 205MHz out of it at 100mV which isn't too bad with some careful substitution of VHF transistors.
Kicked my motivation a bit finally. Sleep and coffee appears to help.
MrBungle is offline
