Old 12th Nov 2016, 9:27 pm   #41
G6Tanuki
G6Tanuki's Avatar
Default Re: Immobile Woodscrews!
One trick I've found works well is to use a screwdriver which has the metal-bit run all the way through the handle ( these have a special name which I forget: the ones I have also have a hex section on the shank immediately below the handle which is great because you can use a spanner to turn it while pressing the blade into the screw-slot with your other hand ).
Put the screwdriver straight in the slot then give the metal-bit-protruding-through-the-handle a good whack with a hammer.
The shock - being conducted down the metal blade - does its thing to loosen the grip between the screw and the wood.
Doesn't always work though: I have a 160-year-old house with a lot of oak used in the construction. Over a century or so the tannins in the wood corrode all iron nails/steel screws to utter irremovability!
I use the same "shock" trick when faced with socket-headed grubscrews in bakelite control knobs - though don't tap the allen-key too hard or it can snap off inside the socket of the screw....
G6Tanuki is offline
Old 12th Nov 2016, 10:22 pm   #42
I am wondering if the screw in post one is now undone?
Old 12th Nov 2016, 11:36 pm   #43
Oldcodger
Originally Posted by Refugee View Post
That looks like the kit I showed in post#24.
You must have had better luck/or it's better quality than Tool Station stuff - my screws came out after getting them giot with a blunt drill and melting the plastic plug.
Oldcodger is offline
Old 13th Nov 2016, 12:12 am   #44
Goldie99
..... it was out a couple of days ago (Post #16)
Goldie99 is offline
Old 13th Nov 2016, 12:50 am   #45
The Philpott
The Philpott's Avatar
As G6Tanuki says Oak is a special case- You would think that galvanized fixings would be ok, but no- it eats through zinc as well.
The Philpott is offline
Old 13th Nov 2016, 7:41 am   #46
stevehertz
stevehertz's Avatar
Oak is the devil's wood. Many years ago before I knew how tough old oak was I tried fixing an old, loose oak chair using a few nails. The nails would literally not go into the wood at all, it was like trying to drive a nail into metal. So hard is old, seasoned oak.
stevehertz is offline
Old 13th Nov 2016, 9:15 am   #47
Stockden
Hammer through?
Hugh
Stockden is offline
Old 13th Nov 2016, 9:32 am   #48
ms660
ms660's Avatar
Oak's OK, you need to use the proper fixings, stainless steel, phosphor bronze, oak pegs etc. For nails and screws pilot and clearance holes are essential, for oak pegs you should drill offset holes for the draw.
Lawrence.
ms660 is offline
Old 13th Nov 2016, 11:08 am   #49
David G4EBT
David G4EBT's Avatar
True - the high tannin level in oak reacts badly with steel screws, which will turn the oak black and over time, the screws will be next to impossible to remove.
Taking the thread a little further off the original topic, this blackening phenomenon is used by woodturners and woodworkers to advantage for ebonising oak, whereby 0000 grade steel wool is dissolved in vinegar over a few days to make an ebonising stain. (The steel wool must first be washed with detergent to remove any oil which will be present due to the manufacturing process). When applied to oak, and to a lesser extent walnut and cherry) it turns the wood to a dark colour - in the case of oak, it looks rather like ebony, due to the reaction of the iron acetate with the tannin in the oak.
Fine, if that's the appearance you're seeking, but not useful if you want to avoid staining a wooden cabinet through the use of steel screws. See:
http://www.popularwoodworking.com/te...ebonizing_wood
https://www.youtube.com/watch?v=fUWw...#t=154.4116863
Very unwise to use wire wool for finishing oak radio cabinets prior to applying a finish such as oil or varnish as tiny fragments will lodge in the grain, can't then be removed, and over time, will react with the tannin in the oak. Use a cabinet scraper or say 240 - 600g wet and dry, or Mirka 'Abranet' which doesn't clog.
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is offline
Old 13th Nov 2016, 5:35 pm   #50
mark_in_manc
What a great thread. I really enjoyed post #32 - thanks David.
I'd echo the idea of hanging onto an old-style carpenters brace for undoing tight screws, and keeping screwdrivers with broken handles to make bits for it - and hollow grinding the tips for a good fit. Actually, I have a short screwdriver bit with the big diamond-shaped lump on it which you see on old-style wood bits, which fits the jaws in my brace as first intended - so this is an idea which has a long pedigree.
A while back I inherited several boxes of Nettlefolds No 6 bronze 3/4 wood screws (ex Ferranti, oddly) and now I know to keep them for if I ever make something in Oak!
(Oh - and valve grinding paste works for getting a firmer grip, as does fine emery cloth (rough side in) under Stilsons (careful!) if you ever have to get hold of something smooth 'around the outside').
...just to add, in the spirit of post 32, one more I found on another forum which really made me smile:
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
mark_in_manc is offline
