Old 7th Nov 2016, 9:22 pm   #1
Radio_Doctor
Radio_Doctor's Avatar
Default Pifco Bubblelites bulb query
I bought this set ages ago and Christmas is coming allegedly.
There are 8 of the mes bulb holders, 7 tubes and 7 base coloured globes. Out of the bulbs only one tests as functional. With my eyepiece I believe they are 30V, 4W.
Can I ask:
1) I can't find these bulbs anywhere. Any suggestions? They are larger than the standard radio mes, presumably with a function of heating the liquid in the tubes.
2) Assuming I can't buy spare bases and tubes, is there a safe work around for the missing bulb/base? Guess I could just buy the 8 bulbs if they are available anywhere and run one as freestanding.
This won't be left on unsupervised and please assume no toddlers able to poke. I have done a fair search for these bulbs and failed so far. Any advice appreciated.
Kneale
Radio_Doctor is offline
Old 7th Nov 2016, 9:25 pm   #2
Radio_Doctor
Default Re: Pifco Bubblelites bulb query
Can't seem to load photos - sorry for ineptitude!
Old 7th Nov 2016, 9:35 pm   #3
paulsherwin
paulsherwin's Avatar
It is reasonably easy to find 34V 3W MES bulbs as these were used in those sets of 7 'candles' which used to be popular. I don't know if the bulb envelope would fit though.
The only alternative I can think of is to use 24V 2W or 5W automotive bulbs and fit a 1N4007 in the plug to reduce the power appropriately. You might have to experiment a bit. 7 lamps will probably work better than 8 with this setup.
paulsherwin is online now
Old 7th Nov 2016, 9:40 pm   #4
Radio Wrangler
Radio Wrangler's Avatar
It may need the full 4W from each bulb to heat each bubble tube to make it work.
Radio Wrangler is online now
Old 12th Nov 2016, 5:55 pm   #5
broadgage
4 watt E10 bulbs in any voltage are hard to find.
I have seen 5 watt E10 bulbs in both 12 volt and 24 volt on eBay and elsewhere.
I would be inclined to try the 24 volt ones, either 10 in series or 7/8 in series and a dropper resistance. I suspect that these are intended for vehicle use and therefore probably designed for an actual 28 volts.
If run at 23 or 24 volts they should have a long life and also not dissipate the full 5 watts.
In the past I have used 6 volt 3 watt cycle dynamo bulbs in bubble lights, 12 in series from a 70 volt transformer.
broadgage is offline
Old 16th Nov 2016, 1:36 pm   #6
Hunts smoothing bomb
Hunts smoothing bomb's Avatar
RS have these:
http://uk.rs-online.com/web/p/filame...lamps/1717018/
They are rated at 3.6v 1A so close to the 4w rated output you need but coming up with a 28.8v PSU might be the tricky part.
Lee
Hunts smoothing bomb is offline
Old 16th Nov 2016, 2:16 pm   #7
Herald1360
Herald1360's Avatar
28.8V sounds like charging voltage for a 24V lead acid battery.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 16th Nov 2016, 3:21 pm   #8
IanNVJ35
IanNVJ35's Avatar
I have some MES 24 Volt bulbs, round and about 3 Watts. Would they be any use? They are underdriven at 24 so I don't think 30 would be a problem.
IanNVJ35 is offline
