23rd Mar 2016, 3:48 pm | #21 |
Re: Refurbishing Idler Wheels.
Butanone (the 2 is redundant because there are only 4 carbon atoms in a straight line, and you can't have a -1-one -- that would be an aldehyde) is the modern chemical name for what used to be called methyl-ethyl ketone.
Propanone is also known as acetone, and is found in nail polish remover.
24th Mar 2016, 2:01 pm | #22 |
Wouldn't it just be a lot easier and safer to send your idler wheel to one of those nice people who re-furbish them professionally?
24th Mar 2016, 10:11 pm | #23 |
I have a can of Rubber restorer (don't recall the brand name) which i bought from CPC some time ago. Used it on a couple of cassette recorder pinchrollers this afternoon. Hadn't used the product for ages, in fact I forgot that I had the stuff. Seems to do the trick, though!
22nd Apr 2016, 9:57 am | #24 |
With regard to MEK, like others have commented on it, a horrid substance and should be used outside really. I used it in the composing room of the printers in the 60's to clean copper printing plates among other uses. It did make you feel a bit whoosy on reflection. Suddenly we got notice that it had been banned in our works; someone in the country had died from inhalation of the fumes; a lucky escape for us as it was used regularly all day in an enclosed space.
On a lighter note I had a light bulb moment the other day (not sure if anyone had thought about it before) but would it be possible to glue a small cassette belt around the outside of the rubber wheel with hot melt glue top and bottom? I haven't tried this yet, will try and find an old jockey wheel and experiment when I get a spare minute. Refurbishment is very expensive I understand, and even second hand ones are fetching silly prices. |
11th Jul 2016, 11:27 am | #25 |
EUREKA! Having hunted ebay and the web for rubber refurbisher I eventually found this one which works very well on the jockey wheels. Have experimented with some very old wheels I found in a box in the workshop and it brings them back to nearly new. It's around £10 a bottle (unfortunately no smaller sizes available) and sold by several sellers on ebay.
Instructions after experimenting. Firstly run a foam sanding block (fine side) around the rim of the wheel to roughen slightly. Pour a little of the liquid in the bottom of a tin and soak the wheel for around 2 hours. (Leaving overnight produced a few problems, although it worked it took several days of repeatedly drying with a kitchen towel to get rid of the excess which creeps under the rubber top and bottom of the wheel.) Soak the excess away with a kitchen towel two of three times till it feels dry. Then roughen the edge with the sanding block again. Amazing how it softens up the rubber. As a bonus you can use it on your car door rubbers if they have gone a little hard, as this is what it is sold for. Mike. |
