30th Nov 2016, 7:49 pm | #1 |
Beocentre 9500
I rarely see these units, this one came my way with a broken drive cord for the CD drive cover. I've only ever looked at one of these before, and that had the same fault. After a very careful re-string of the drive system for both upper and lower sides of the cover, it all worked. You can use the cassette deck cover as a pattern for the drive cord threading. It really is a horrid job, the service manual was very little help!
Why possessed B&O to use a drive cord rather than a threaded drive, as a CD laser sled does I do not know. After all it can't be cost on these units! The CD laser was still OK, not bad for a unit that's 30 odd years old! SJM |
30th Nov 2016, 8:10 pm | #2 |
Re: Beocentre 9500
I just got an unit like this. It had a problem with the 5v supply which I now think is ok, but I still have a lot of dry joints to take care of.
The glass pieces came off, but luckily they didn't break. |
