Old 6th Jul 2016, 3:44 pm   #1
johnny
Default Have a torn speaker cone ?
All is not lost no matter how bad the tear is. I carefully realigned the tear up and then applied a coat of black nail varnish to both sides of the tear and left to dry. Once it had dried, I applied another 2 coats and once dried, the speaker was as good as new
johnny is offline
Old 7th Jul 2016, 2:44 am   #2
MurphyNut
MurphyNut's Avatar
Default Re: Have a torn speaker cone ?
I would imagine we all have our own ways of repairing speaker cones, I soak small strips of paper in PVA wood glue (50/50 - water/glue) and lay these across the damaged areas.
Once dry this really makes a permanent repair, I like the way the glue from the strips soaks into cone and it all becomes one, rather than just sticking onto the surface. I finish off by painting the cone with a thin coat of black paint, I know this last part of the process isn't necessary but it finishes it off nicely.
Clive
MurphyNut is offline
Old 7th Jul 2016, 3:06 am   #3
Ti Pwun
Ti Pwun's Avatar
I would also go with something flexible like PVA wood glue. After a while, the nail varnish will crack and break free, especially if the volume is used at a high level.
Ti Pwun is offline
Old 7th Jul 2016, 10:20 am   #4
threeseven
threeseven's Avatar
I use black silicone gasket, applied generously to thoroughly coat the area then scrape off the excess and leave to set over a few days. I like the way it remains flexible.
BVWS member
threeseven is offline
Old 7th Jul 2016, 12:22 pm   #5
Ian - G4JQT
Ian - G4JQT's Avatar
Copydex rubber solution glue, watered down about 50:50. Use kitchen towel which stronger than other tissues and flexible.
Push the tear back into place as best you can. Dab area with glue from both sides if possible. Lay on paper slightly larger than damaged area and gently dab with more glue.
The glue solution is very flexible, actually soaks into the cone (so won't ever peel off) and is all held together by the paper which will cover any holes or missing scraps. The paper wrinkles up at first, but flattens and tightens when dry.
Ian
Ian - G4JQT is offline
Old 7th Jul 2016, 2:29 pm   #6
johnny
Well, there are many ways it seems to get that speaker working again. I bet there are a lot more ways to do it, so lets hear about them.
johnny is offline
Old 7th Jul 2016, 10:23 pm   #7
Silicon
Ideally the 'bandage' applied to the cone should be as light and strong as possible.
Anything that adds mass or changes the flexibility of the cone will affect the sound.
I have often wondered if the synthetic fibre sheets used for anti-weed mesh would be better than paper.
Silicon is offline
Old 8th Jul 2016, 4:27 pm   #8
johnny
Most tears I have seen can easily be "threaded" or stitched. It takes a little patience as one has to do both side of the tear. A dentist's shap ended tooth pick is a good tool to have as one can lift the fibers and mesh them before applying the magic solution. Ofcourse, the bigger the speaker, the more vibration of the cone at higher levels.
johnny is offline
Old 8th Jul 2016, 5:48 pm   #9
emeritus
Last year I did a course on bookbinding (some of my electrical textbooks are more than 100 years old and very much in need of restoration). One thing I learned was that restorers use Japanese paper made from long fibres of the Mulberry tree for reinforcing in general, and mending tears in particular. A type I was recommended to use is Kizuku Tosa Kozo in 18gsm (the weight normally used by the British Library for their restorations). It is so thin and translucent that it can be applied over text, and certainly not cheap (£13.25 for an approx. 2' x 3' sheet), but as only a thin strip needs to be applied across a tear, it goes a long way.
When still wet, can be moulded in three dimensions to reinforce corners and embossing, so it would be suitable for mending the corrugations at a speaker's edge. I haven't needed to repair any speakers recently, but I would use this for any that might come my way in future. I have used it to restore missing corners of pages, applying one piece from each side, so it could be used to bridge holes. When the glue has dried it is certainly very strong and flexible. I use a fast-drying archival quality pH-neutral PVA-type glue (EVA) intended for book binding that will not attack paper and does stay flexible when dried: apparently PVA glue intended for woodworking is somewhat acidic and prone to damage the type of paper used for books.
emeritus is offline
Old 9th Jul 2016, 9:14 am   #10
Ti Pwun
Ti Pwun's Avatar
Very interesting post. I don't repair many speakers but that's definitely useful info.
Ti Pwun is offline
Old 9th Jul 2016, 10:26 am   #11
emeritus
I forgot to mention that, because the Japanese paper is hand made, the fibres lie at random orientations, so there is no direction of weakness. Machine made paper is made in long webs and its fibres are aligned along the axis of the web. Thus you can easily tear a sheet of toilet paper along its length, but it is difficult to tear across its width, other than at the perforations.
emeritus is offline
Old 10th Jul 2016, 10:19 am   #12
Ti Pwun
Ti Pwun's Avatar
Definitely sounds like it's the right material for the job. Thanks.
Ti Pwun is offline
Old 11th Jul 2016, 2:23 am   #13
FrankB
I have used both toilet paper and tissue paper to repair cones with.
General Cement made a flexible cement specifically for cone repair.
Lacking the cement, I have used a very thin coat of RTV silicone sealant.
FrankB is offline
