Old 17th Sep 2017, 7:20 pm   #1
Hsustyle
Default Power plug advice? Pics Inside
I'm new to the forum and can't seem to find what I need from the search section.
Need a pointer as to what power supply I need to get this running -
Type V
Garrard unit D15 motor
My partner picked this up at a boot fair, I believe the box these two are in is not standard.
Any advice much appreciated.
ID:	149603   Click image for larger version
ID:	149604   Click image for larger version
ID:	149605   Click image for larger version
Hsustyle is offline
Old 17th Sep 2017, 8:34 pm   #2
ms660
ms660's Avatar
Default Re: Power plug advice? Pics Inside
That looks like a chassis mounted Bulgin socket (the pins are actually a plug) if it is you will need the plug (the contacts are actually sockets) Search Google images for......vintage bulgin plugs sockets.
Lawrence.
ms660 is offline
Old 17th Sep 2017, 8:40 pm   #3
Nuvistor
Nuvistor's Avatar
Don't think about applying any power until you confirm what's inside the cabinet and do any work to make it safe . This may sound harsh but the age of the wiring inside could well have rotted insulation etc.
I have not seen one before so cannot comment on what you will find.
Frank
Nuvistor is offline
Old 17th Sep 2017, 8:53 pm   #4
Station X
Station X's Avatar
This type of motor has featured in the forums before:-
http://vintage-radio.net/forum/showthread.php?t=139711
Graham. Forum Moderator
Station X is online now
Old 17th Sep 2017, 9:01 pm   #5
Hsustyle
Great stuff, appreciate the speedy replies, I'll do some more research and take the box apart.
Hsustyle is offline
Old 17th Sep 2017, 11:22 pm   #6
Techman
Techman's Avatar
You'll also need to re-build the pickup heads as the rubber parts will have gone rotten and be solid which will cause low or no output and will damage records. It's for 78rpm records only and needs steel gramophone needles that have to be replaced after every record side.
Techman is offline
Old 18th Sep 2017, 9:25 am   #7
Hartley118
Hartley118's Avatar
Being a twin-turntable unit, this is designed for continuous play of a sequence of discs. It was probably used for public performance in a theatre, dance hall or cinema.
You could say that it was the basis of a 1930s/40s disco!
Martin
BVWS Member
Hartley118 is offline
Old 18th Sep 2017, 10:21 am   #8
julie_m
There doesn't seem to be any facility for pre-fade listening, unless you were expected to hold your ear up close to the pickup and listen out for the needle chatter?
julie_m is offline
Old 18th Sep 2017, 10:33 am   #9
Nuvistor
Nuvistor's Avatar
Be interesting to see what's inside, the cabinet looks quite shallow to have 1930's amplifier in it.
Frank
Nuvistor is offline
Old 18th Sep 2017, 7:05 pm   #10
Hartley118
Hartley118's Avatar
That was probably sufficient. Any misjudgement at 78 rpm was short-lived!
In any case, 'scratching' the record backwards with that trailing steel needle was not a good idea.
Martin
BVWS Member
Old 18th Sep 2017, 7:33 pm   #11
camtechman
camtechman's Avatar
AKA: a "Chassis Mounted Plug"
If it is you will need the plug (the contacts are actually sockets)
AKA: a "Cable Fitting Socket"
Boom Boom
When I die, please don't let my Wife sell my collection for the amount I told her I paid for it!
camtechman is offline
Old 18th Sep 2017, 7:39 pm   #12
ms660
ms660's Avatar
Hence the suggestion to Google some pics...
Lawrence.
ms660 is offline
Old 18th Sep 2017, 8:52 pm   #13
frankmcvey
H'mm - I'm not so sure about Bulgin... The standard 5A (abt 22mm dia "pig's nose") Bulgin chassis plug/flying socket as used in a number of vintage amplifiers had a different keyway orientation wrt to the pins, like this one
Having said that, there's nothing to stop you replacing the old chassis plug with a NOS 5A Bulgin chassis plug, assuming they're the same physical size or fairly close. However, as you can see, the free/flying Bulgin sockets are VERY expensive now...
Cheers,
Frank
frankmcvey is offline
Old 18th Sep 2017, 9:59 pm   #14
ms660
ms660's Avatar
Bulgin did do a 3 pin connector with the keyway in same orientation as in the OP's photo:
http://www.vintage-radio.net/forum/a...9&d=1443730409
Also regarding the "is it a plug or is it a socket"..."Plugs have pins..Sockets have sockets" their words here:
https://picclick.fr/Rare-SA480-3-Pin...#&gid=1&pid=10
Lawrence.
ms660 is offline
Old 18th Sep 2017, 10:17 pm   #15
frankmcvey
Ah, so! Mr Bulgin was pretty prolific, then.
Cheers,
Frank
Old 22nd Sep 2017, 11:26 am   #16
Station X
Station X's Avatar
Several posts moved to a new thread here:-
https://www.vintage-radio.net/forum/...d.php?t=140012
Old 22nd Sep 2017, 6:17 pm   #17
peter_sol
That is a Bulgin
Someone must have one to spare.
peter_sol is offline
