Old 17th Sep 2017, 8:02 am   #1
Oldelectronics
Default Hacker Black Knight RP74MB
Hi folks
I recently bought A fairly grubby ( but inexpensive) example of this set I can't though see a service sheet for it? Could I use the Sovereign RP72MB sheet as I believe it's basically the same set but is FM only? Also could anyone suggest the best way to clean the aluminum front without fetching off the lettering?
Kind Regards
Kev
Name:	Hacker Black Knight.jpg
Oldelectronics is offline
Old 17th Sep 2017, 11:51 am   #2
Radiocruncher
Radiocruncher's Avatar
Default Re: Hacker Black Night RP74MB
Hi Kev
The RP72 manual also covers the RP74 so should be fine. The black print on these is extremely fragile. I would use hand soap and water with a cotton bud very gently. Do not use foam cleaner as it's great at removing all the print. It does look like someone has used a permanent marker to colour it back in though.
Good luck
Graham
Radiocruncher is offline
Old 17th Sep 2017, 3:54 pm   #3
Oldelectronics
Thanks for that Graham much appreciated. I dont believe though that I put Night and not Knight !!!
Regards
Kev
